New To Riders And Got A Question
49 replies to this topic
#31 KennyP ONLINE
  • 40,183 Thanks
  • 46,794 posts
Posted November 24, 2013 - 10:28 AM
i would but its just to cold for me to tear into it i dont have a heated or exactly weather proof garage its seen better days
Sent from my LG-P769 using Tapatalk
I know that situation!
#32 TAHOE ONLINE
TAHOE
  • 8,181 Thanks
  • 5,764 posts
Posted November 24, 2013 - 08:33 PM
Yea, sounds like the bushings on the steering shaft where it meets the other gear are worn. This allows slop in the gears which can lead to jumping teeth. You can try to find replacement bushings and try to rebuild.
I would suggest your best bet is to go to sears parts direct, type in your model number, then find the steering sector gear assembly. Either buy it from sears if they have it or use part numbers and find them probably cheaper on ebay.
Bad part on these, you have to tear half the tractor apart to get to the gears, dash, battery tray, etc all have to come off just to get to the assembly.
#33 Walkinman1 OFFLINE
Walkinman1
  • 769 Thanks
  • 586 posts
Posted November 24, 2013 - 10:27 PM
I have a complete steering gear assembly off of a newer lawn tractor that's still good. If it would interchange and work I'd be willing to part with it...
#34 KennyP ONLINE
  • 40,183 Thanks
  • 46,794 posts
Posted November 25, 2013 - 08:02 AM
What model is it from? I can see if it will interchange with that.
#35 Walkinman1 OFFLINE
Walkinman1
  • 769 Thanks
  • 586 posts
Posted November 25, 2013 - 09:54 AM
I'll check in a few hours when I get home and let you know Kenny
#36 tractorguy2 OFFLINE
tractorguy2
  • 8 Thanks
  • 17 posts
Posted November 26, 2013 - 08:52 AM
momment of truth soon getting a winter storm ill be taking the 18 horse out im picky though i wont put a engine that small under that big of a load unless its at full running temp
#37 Walkinman1 OFFLINE
Walkinman1
  • 769 Thanks
  • 586 posts
Posted November 26, 2013 - 09:43 AM
Sorry about the delay guys, got home a lot later than expected. Kenny, it's an LT 1000 (one of the dark gray era models) but I can't find a serial number on the frame anywhere. If it's necessary maybe you can point me towards where to look for it? Here's a couple pics of the gear in case that helps...
#38 KennyP ONLINE
  • 40,183 Thanks
  • 46,794 posts
Posted November 26, 2013 - 09:51 AM
Sears parts won't pull up LT 1000. I would need the 917? # off it. Maybe tractorguy2 will see this and let us know if it looks like his!
#39 tractorguy2 OFFLINE
tractorguy2
  • 8 Thanks
  • 17 posts
Posted November 26, 2013 - 02:58 PM
http://gardentractortalk.com/forums/public/style_images/GTtalk/attachicon.gif uploadfromtaptalk1385476971273.jpghttp://gardentractortalk.com/forums/public/style_images/GTtalk/attachicon.gif uploadfromtaptalk1385476981919.jpg
looks kinda like mine i dont have the mower apart but the bar that goes through the hole in the flat gear moves when i turn the wheel then the gear would
#40 Walkinman1 OFFLINE
Walkinman1
  • 769 Thanks
  • 586 posts
Posted November 26, 2013 - 03:16 PM
Kenny I can't find another number anywhere on the frame or body. Do you know where the 917... number would be?
#41 TAHOE ONLINE
TAHOE
  • 8,181 Thanks
  • 5,764 posts
Posted November 26, 2013 - 03:36 PM
Take a gander at this thread, this guy rebuilt his, but it has pics showing the assemblies torn apart. They were pretty much same parts late 80's through late 90's.
http://www.mytractor...hlight=steering
#42 KennyP ONLINE
  • 40,183 Thanks
  • 46,794 posts
Posted November 26, 2013 - 03:43 PM
Like most Sears, it was probably under the seat on a decal that is long gone.
I can't say whether any of this will work. All these steering parts are different from the tractors I have.
#43 Walkinman1 OFFLINE
Walkinman1
  • 769 Thanks
  • 586 posts
Posted November 26, 2013 - 04:40 PM
It was covered in snow and I never even thought to look up there :banghead: uploadfromtaptalk1385502022718.jpg
#44 tractorguy2 OFFLINE
tractorguy2
  • 8 Thanks
  • 17 posts
Posted November 26, 2013 - 05:35 PM
i started the 18 horse up and the left hand cylinder drips oil from the sparkplug and it burns oil any thoughts?
#45 KennyP ONLINE
  • 40,183 Thanks
  • 46,794 posts
Posted November 26, 2013 - 05:42 PM
Thanks. That is totally different than his. It's also different than a GT18.
