Engine Questions Jd Model 210 & 214
john deere model 210 214 engine swap
20 replies to this topic
#1 maydog96 OFFLINE
maydog96
  • 3 Thanks
  • 2 posts
Posted November 20, 2013 - 11:36 PM
Hello GT Talk members! I'm new here but I hope to fit right in! :)
I have a couple questions about motors in these old JD's, I have a 210, and a 214 parts tractor at the moment, along with a 317 that's doing just fine. I wanted to try and put the 14hp Kohler from the 214 into the 210 as the 10hp Kohler from the 210 needs rebuilt. So does the 14hp Kohler, But I figured I'd like to get the 14hp going first, if it would fit in the 210 as the 214 was a parts tractor to begin with. So I guess what im asking is a couple things. Will that 14hp Kohler bolt right up to the 210? Both earlier model vertical shaft Kohlers. Also, has anyone rebuilt one of those before? any tips?
Any Help is greatly appreciated!
Thanks in advance,
Mason
  • WNYTractorTinkerer, A.C.T. and chevy2003 have said thanks
#2 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,625 Thanks
  • 1,311 posts
Posted November 21, 2013 - 12:42 AM
I think you meant horizontal shaft. It should bolt right in i believe,without any problems.
  • maydog96 said thank you
#3 Alc ONLINE
  • 6,887 Thanks
  • 7,461 posts
Posted November 21, 2013 - 06:18 AM
Welcome Mason to GTTalk !
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted November 21, 2013 - 06:34 AM
Welcome to GTTalk. I'm not that familiar with the 200 series but I think the Kohlers have a common base size so it should mount. If you look on JDparts.com and do a model number search for the 2 tractors you can look at the parts diagrams. This will tell you if the belts, pulleys/ motor mounts etc are different part no's/ sizes.  Since you have the 2 tractors it should be possible to swap any needed parts over and you should be good to go.
#5 jms180 OFFLINE
jms180
  • 1,517 Thanks
  • 1,567 posts
Posted November 21, 2013 - 06:53 AM
I am of no help but welcome to GTT
#6 boyscout862 OFFLINE
  • 12,864 Thanks
  • 9,175 posts
Posted November 21, 2013 - 08:42 AM
Welcome to GTT. You can check our manuals section for the Kohler manuals and download three for free per day. You can search our site for threads on Kohler rebuilding. OEM parts are expensive. After market kits are very reasonable(about $110 to $170) on EPAY. I plan to do several Kohler engines this winter. Good Luck, Rick
Edited by boyscout862, November 21, 2013 - 08:42 AM.
#7 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 10,470 Thanks
  • 5,770 posts
Posted November 21, 2013 - 09:48 AM
Welcome to GTtalk Dog!
Word of advice about the 14hp Kohler..
When you rebuild it, leave the balance gears out when you put it back together...  (aka-  Grenade gears!)
Lots of banter about those things and the shear carnage they cause..
Lot's of Kohler pros here so don't hesitate to ask questions!
I'm out!
  • maydog96 and chevy2003 have said thanks
#8 Trav1s OFFLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted November 21, 2013 - 10:09 AM
JDparts shows the engine mounts are same on the 210/212/214's if in same serial number range so you "should" be able to swap from one to the other.
AM34866 BASE      - 70000              (210, 212 AND 214)
AM36830 BASE      70001 - 80000   (210, 212 AND 214)
Use the base that is from the tractor you are installing in for the swap to ensure it goes easy.
#9 lyall OFFLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted November 21, 2013 - 12:39 PM
it depends on the motor mounts
there are two different motor mounts - a two piece and a one piece
from what I remember the 10 hp, 12 hp and 14 hp are very close in design
sometime the oil pan are different  - 1-1/2 qt or the 2 qt
you will have to make adjustments to work right - like the pto linkage
#10 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,773 Thanks
  • 4,265 posts
Posted November 21, 2013 - 12:58 PM
hi Mason and welcome to GTT
as seen in JDPC, a model exchange seems to be possible. please report us your further work ildeere.gif
#11 maydog96 OFFLINE
maydog96
  • 3 Thanks
  • 2 posts
Posted November 21, 2013 - 01:29 PM
Thank you everyone! I will be sure to report back with any real progress. This will most likely be a winter project, so I may have more questions in time :) Oh, and I did mean Horizontal shaft.. can't believe I made that error.
#12 210newbie OFFLINE
210newbie
  • 1 Thanks
  • 4 posts
Posted June 06, 2014 - 07:09 AM
Hi,
I just found this thread and looking for some info on 210 engines as well. I just bought a 210  with a 10hp runs but tired- I am looking around for a new motor to put in.
I found a K321 ( 14hp)  that looks to be in good shape/ complete ( exhaust & carb), but think it was in something else possibly a pump. it is a horizontal shaft, but the dip stick for the oil is down low not up with a tube like on the 10hp I have- think that might be ok though could put a tube on it.
 The price is good less  than $100-  but wondering if this will fit into the 210.  The numbers on the motor are k321ep, spec#6056D.
I know the 214's used a K321-  wondering if anyone can tell me if this motor would fit in there without having to change a bunch of stuff. Don't want to start cutting things up "butchering" things just to get it in.
Any help or thoughts greatly appreciated
thanks
#13 210newbie OFFLINE
210newbie
  • 1 Thanks
  • 4 posts
Posted June 06, 2014 - 07:58 AM
so did a  bit more researching on my end on the kohler# and seems that the ep means it was on a generator- so wondering if this would make a difference- in my thoughts about putting it in a 210 tractor?
#14 Trav1s OFFLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted June 06, 2014 - 08:38 AM
Do you have any pics of the two engines in question?
#15 210newbie OFFLINE
210newbie
  • 1 Thanks
  • 4 posts
Posted June 06, 2014 - 02:35 PM
I do not have any photos yet- of the motor in my 210- I believe it to be the original- 10HP- I bought the unit from the original owner.
It starts right up and runs fine, but its tired. My property is hilly so you feel it on the grade going up-  its chugging. Not bad where its flat.
My thoughts were if the 14hp ( k321) was an easy swap I would pull the head, check to see what it looked like and if need be put a rebuild into it then swap the 10hp out. I could then rebuild the original motor if I wanted to have as a spare.
Here are some photos of the k321 I can get for about $75- Think it probably was on a generator- not sure. I have not seen it yet, but its suppose to run, and looks to be pretty complete. I am wondering if things like the starter, oil pan, etc are the same, or completely different. Even though its pretty cheap- would hate to get it, if it would not work. so obviously trying to find that out here.
I will try to post shots of the motor in my 210 over the weekend- not planning on yanking the motor until I have another one to put in, as it still runs.
Thanks for taking the time to look-
Best
Scott V
Also tagged with one or more of these keywords: john, deere, model, 210, 214, engine, swap
