It Is Known As An St-10.
22 replies to this topic
#16 farmerall OFFLINE
farmerall
  • 2,204 Thanks
  • 1,474 posts
Posted November 21, 2013 - 09:59 AM
I's also like to know, farmerall, if that machine has the chaindrive to the rear axle of a belt drive. In the parts diagram it shows a belt. I have a chain and sprocket. It's on your right side as you sit on the tractor.
Mine had a belt that went to the rear axel.
  • EricFromPa, JRJ and MyBolens1053 have said thanks
#17 UncleWillie ONLINE
  • 15,676 Thanks
  • 8,763 posts
Posted November 21, 2013 - 06:01 PM
Nice little worker. I like that front bumper.
  • MyBolens1053 said thank you
#18 MyBolens1053 OFFLINE
MyBolens1053
  • 643 Thanks
  • 574 posts
  • Location: Martinsburg, WV (surrounded by Apple Orchards)
Posted November 21, 2013 - 07:35 PM
Yeah. It's solid and does a good job for pushing and pulling with a chain.
#19 BushBoneYard OFFLINE
BushBoneYard
  • 36 Thanks
  • 70 posts
Posted November 25, 2013 - 07:32 PM
Nice Murray. I have seen that tractor before, God only knows where though, I search Murray's just about daily. I have an ST 10 myself.
#20 MyBolens1053 OFFLINE
MyBolens1053
  • 643 Thanks
  • 574 posts
Posted April 19, 2014 - 09:41 PM
Finally getting to do a little maintenance on the old machine. I have a 'new to me' stack pulley for the motor and will attempt to change the stack in the morning. The original got a ding in it and is now chewing and flipping the deck drive belt. Found the shaft screw to be a 9/16" hex head bolt. Now to figure how to pull the stack off the shaft without a puller and not banging up the threaded opening of the shaft. Maybe an impact socket with a washer inside the stack and use an air chisel while pulling down with a prybar on top? Ideas?
#21 MH81 OFFLINE
Posted April 20, 2014 - 06:45 AM
Your best options would be to go buy the right puller or make a custom one.
If you happen to have a piece of brass the right size to drop in there, might be a good idea.
#22 MyBolens1053 OFFLINE
MyBolens1053
  • 643 Thanks
  • 574 posts
Posted April 20, 2014 - 12:15 PM
Well, I found that my neighbor has a puller rig and guess what. The pulley won't budge. Guess I'll need to spray it down with PB Blaster.
#23 MyBolens1053 OFFLINE
MyBolens1053
  • 643 Thanks
  • 574 posts
Posted April 27, 2014 - 10:14 PM
I finally got back to this project today. Ended up taking the motor out of the tractor, buying an 8" puller at Tractor Supply and going at it. Still wouldn't budge. Heated the pulley. No go. Since the pulley was already bent I said screw it and started tapping downward with a 5 lbs. hammer. Little by little it slid off the shaft. Once it was off I wondered why the puller was still holding on. Dismantled the puller and lo and behold, there were still 4 more washers inside the pulley tube!!!
That made a total of 6 washers and a locking washer inside the stack pulley. CRAP!!!!
Well, all is good now. Another stack pulley is on, motor back on the tractor and it runs like it should. This all done by sundown. Going to mount the deck in the morning and test it out.
  • MH81 and toomanytoys84 have said thanks
