It Is Known As An St-10.
22 replies to this topic
#1 MyBolens1053 ONLINE
MyBolens1053
  • 640 Thanks
  • 570 posts
  • Location: Martinsburg, WV (surrounded by Apple Orchards)
Posted November 20, 2013 - 10:13 PM
Hello everyone. Don't let my pride and joy Bolens 1053 fool you. It has another worker on my grounds known as a Sears ST-10. Mne is the 502.25910 mentioned below.
"In 1976, Sears began to sell what they labeled a garden tractor, which was produced by the Murray Company. They were called ST/8 and ST/10 in 1977, model numbers 502.25900 and 502.25910. These machines were not made by the Roper Company".
This little machine has some 'cajones' for a 10hp B&S powered machine. It cuts well. It pulls logs and a 5' x 8' trailler with a ton of weight on it. The only drawback with this machine is PARTS and attachments. I did find a 3-pt. hitch for it. And I was able to find a spare cutting deck for it, too. That was a shocker.
Anywho ... here's some pics.
  • rustyoldjunk, MH81, Alc and 6 others have said thanks
#2 MH81 OFFLINE
Posted November 20, 2013 - 10:24 PM
Nice looking ST. Thanks for sharing.
The lift looks like the older two bolt lifts for the early customs
  • JRJ and MyBolens1053 have said thanks
#3 farmerall OFFLINE
farmerall
  • 2,202 Thanks
  • 1,473 posts
Posted November 20, 2013 - 10:34 PM
Nice tractor, it was built by Murray and most of the parts from a Murray will interchange. Also if you are looking for another deck I have one that you can have. I'm tired of seeing it sit around and want it gone.
  • IamSherwood, JRJ, Sawdust and 1 other said thanks
#4 robert_p43 OFFLINE
robert_p43
  • 572 Thanks
  • 534 posts
Posted November 20, 2013 - 10:49 PM
Looks like a worker.  I have searched all over for a top link like the one that is with your 3 point hitch.  I need to find a chain for moving things like you are doing there with the log.
#5 EricFromPa ONLINE
EricFromPa
  • 3,525 Thanks
  • 3,071 posts
Posted November 20, 2013 - 10:51 PM
They were good tractors.
The one that I had was run low on oil and the crank and cylinder bore was scored.I would of kept it but I could not find another engine with a Stepped crank and I didn't want to spend the money to have another engine crank turned down.
1" of the crank on the end is turned down to 3/4" and 1/4" key and a bolt hole in the bottom.It's not a standard 1" or 1 1/8" crank.Makes it really hard to repower using the original pulley set up.
I had a nice deck,snow plow and the original sears wheel weights and tire chains for it.
I had a 15hp Kohler Command single cylinder that I was going to repower it with but that never happened.
  • Alc, farmerall, JRJ and 1 other said thanks
#6 MyBolens1053 ONLINE
MyBolens1053
  • 640 Thanks
  • 570 posts
Posted November 20, 2013 - 10:53 PM
farmerall, I'll let you know when I plan on passing that way if you don't mind holding on to it a while longer. Thank you.
  • JRJ said thank you
#7 MyBolens1053 ONLINE
MyBolens1053
  • 640 Thanks
  • 570 posts
Posted November 20, 2013 - 10:55 PM
I found this hitch at a bone yard in Bedford, PA. He's on CL all the time. The chain is a typical 25' tow chain from Lowes.
#8 MyBolens1053 ONLINE
MyBolens1053
  • 640 Thanks
  • 570 posts
Posted November 20, 2013 - 10:58 PM
I heard a guy in VA repowered one of these and used a dual pulley setup to match the shaft of the new motor. Not sure of his sources for the pulley.
#9 farmerall OFFLINE
farmerall
  • 2,202 Thanks
  • 1,473 posts
Posted November 20, 2013 - 11:10 PM
I never knew these had a special crankshaft. I have an engine from one sitting in my shed and now I'm curious so I have to go pull the pulley off lol.
Here is a picture of what mine looked like when I found it.
  • Alc, JRJ and MyBolens1053 have said thanks
#10 MyBolens1053 ONLINE
MyBolens1053
  • 640 Thanks
  • 570 posts
Posted November 21, 2013 - 12:08 AM
Well, seeing this, it makes one wonder why someone would allow this to happen to a beast of a machine. Yes, that B&S has a special size shaft. The pulley stack is still available through Sears at a price above $40.00.
#11 MyBolens1053 ONLINE
MyBolens1053
  • 640 Thanks
  • 570 posts
Posted November 21, 2013 - 12:12 AM
I's also like to know, farmerall, if that machine has the chaindrive to the rear axle of a belt drive. In the parts diagram it shows a belt. I have a chain and sprocket. It's on your right side as you sit on the tractor.
#12 MyBolens1053 ONLINE
MyBolens1053
  • 640 Thanks
  • 570 posts
Posted November 21, 2013 - 12:48 AM
A few more pics of this ST-10. You can see how much wood it pulled last year.  :rocker2:  This front of the porch was stacked to the top of the rail arounf the porch by the time I finished 1/2 a tree.
#13 KennyP ONLINE
  • 37,505 Thanks
  • 45,509 posts
Posted November 21, 2013 - 06:20 AM
Nice looking ST-10! Looks like you are working it pretty good!
#14 glgrumpy OFFLINE
  • 8,564 Thanks
  • 7,881 posts
Posted November 21, 2013 - 07:28 AM
My first GT back about 76 was an ST8. Only 8horse and manual transaxle but had big tires/wheels like bigger machines. Had deck for it and a diff Sears blade I bought on close-out and had a shop make mounts on tractor for it. It did real well. I don't recall where it went? I know I bought a JD 110 about 78, just don't recall if I traded or sold that Sears,mmmm, weird!
Edited by glgrumpy, November 21, 2013 - 07:30 AM.
#15 TAHOE OFFLINE
TAHOE
  • 7,814 Thanks
  • 5,612 posts
Posted November 21, 2013 - 09:56 AM
I found this hitch at a bone yard in Bedford, PA. He's on CL all the time..
yea, he's a slime ball punk.
I'm sorry, but he just screwed me big time over some parts.
Anyway, nice little tractor. The is an older style 2 bolt hitch, possibly one for the DB suburbans. I have one I was going to cut up and modify to make an electric hitch since it's been welded on before.
I have the same top link, I actually thought it was one of the links for the lower arms, good to know.
