Outdoor Mobile Work Table
11 replies to this topic
#1 Sawdust OFFLINE
Sawdust
  • 5,563 Thanks
  • 3,335 posts
Posted November 20, 2013 - 06:49 PM
I started to clean my gas grill yesterday & realized it was worn out...it already out lived two burner replacements. I MADE A LIST EARLY THIS MORNING TO GET TWO THINGS DONE TODAY & NOT GET SIDETRACKED.  :D   I decided to use the moble cart frame & put a much needed work table on top. I had a lot of short pieces of PT 2x6's so this will be my top. I adjusted the size to the amount of wood I had so I ended up with a table top of 75"L x 32"W. I do a lot of work between my house & garage & I hate setting up saw horses every time I want to do something. The frame bolts had plastic inserts with cheap screws. I replaced them with carriage bolts to make it more stable.  I also finished painting my trailer wheels. I succeeded in getting these two things DONE.
Thanks to all the list makers out there for your inspiration.  :wave:
Edited by Sawdust, November 20, 2013 - 06:52 PM.
  • olcowhand, powerking56, daytime dave and 11 others have said thanks
#2 KennyP OFFLINE
  • 37,582 Thanks
  • 45,541 posts
Posted November 20, 2013 - 06:58 PM
Should have left the side burner on there. Then you could warm lunch or keep the coffee hot! Looks good!
  • olcowhand, hamman, IamSherwood and 2 others have said thanks
#3 Sawdust OFFLINE
Sawdust
  • 5,563 Thanks
  • 3,335 posts
Posted November 20, 2013 - 07:32 PM
I actually thought about doing that as a joke but forgot about it then it got too dark for a pic.  :thumbs:
  • hamman, KennyP and JRJ have said thanks
#4 IamSherwood OFFLINE
  • 8,390 Thanks
Posted November 20, 2013 - 07:49 PM
Looks good. that'll be handy to have around. You could drill a big hole, or
two, and insert a big umbrella in it for those hot sunny, or wet days.
  • hamman, Team_Green, JRJ and 1 other said thanks
#5 MH81 OFFLINE
Posted November 21, 2013 - 07:41 AM
That will be handy. Is it top heavy at all?
  • JRJ and Sawdust have said thanks
#6 daytime dave OFFLINE
  • 4,787 Thanks
  • 6,524 posts
Posted November 21, 2013 - 07:54 AM
I like that idea.  Thanks for sharing it with us.   :thumbs:
#7 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted November 21, 2013 - 09:18 AM
I like your idea for I had done something similar. I removed the worn out burners and inserted a piece of plywood to serve as a table for one of those portable grills which for me worked out good.
Dick .
  • Sawdust said thank you
#8 TAHOE OFFLINE
TAHOE
  • 7,827 Thanks
  • 5,619 posts
Posted November 21, 2013 - 10:13 AM
nice re-purpose. It almost looks like you've got some woodworking experience :poke:  :smilewink:
#9 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted November 21, 2013 - 11:47 AM
Nice work table ..  :thumbs:
I've got a set of four heavy casters out in the garage and was also thinking of making a heavy metal rolling frame work table for them  . I've got a work bench but sometimes it be nice to move a work table to your work project .
 A few years back I used a small gas grill frame for my ( supposedly portable but heavy) 120 volt SP-135 Lincoln welder . I welded a metal top to the frame and a bracket on the rear to hang my welding clamps on .
It makes it nice nice rolling the welder around the garage or out to a project in the driveway .
#10 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted November 21, 2013 - 12:32 PM
It was on my list to read this.  Glad I finally did.  I like the idea and it looks really good!  Now I'm looking at our grill a little differently.
#11 T Guiles OFFLINE
T Guiles
  • 953 Thanks
  • 749 posts
Posted November 21, 2013 - 01:19 PM
It''d be cool to add a small vice to it, might be pretty handy to have.
#12 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted November 21, 2013 - 01:23 PM
Good Repurposing There!  There is a BBQ sitting off to the side for a simular purpose. I'm planning to mount my Compound Miter Saw on it.  By Droping the saw down in the middle I should be able to use the higher ends as infeed and outfeed tables?
Edited by JD DANNELS, November 21, 2013 - 01:28 PM.
  • KennyP and Sawdust have said thanks
