I Built A Gt Bridge.
83 replies to this topic
#46 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted November 23, 2013 - 07:44 AM
Just where it contacts the ground, no need to completely wrap them.
#47 IamSherwood OFFLINE
  • 8,395 Thanks
Posted November 23, 2013 - 07:55 AM
Ok. I'll get a hold of him and get a good pile of those wraps. I've got a couple
of other projects that'll need them too. Thanks for the suggestion.
  • oldedeeres said thank you
#48 KennyP ONLINE
  • 40,901 Thanks
  • 47,100 posts
Posted November 23, 2013 - 08:47 AM
How wide between the rails? The FF needs 54" as it sits!
#49 Sawdust OFFLINE
Sawdust
  • 6,154 Thanks
  • 3,548 posts
Posted November 23, 2013 - 08:58 AM
The ramp looks real natural Will. That's funny about debarking the logs. I knocked off some bumps with a chain saw then started straddling the logs with a draw knife. Needless to say that didn't last long. I would give the tar on the planks some thought first. I would think that would be slippery when wet or freezing.
  • IamSherwood and oldedeeres have said thanks
#50 gtcsreg OFFLINE
gtcsreg
  • 2,089 Thanks
  • 2,040 posts
Posted November 23, 2013 - 09:19 AM
Nice bridge. Just used planks on the end of mine for ramps. The boards running longways are to remind me to stay away from the edges because they wouldn't support the GT. I didn't have any railroad ties long enough for stringers so I used 6X8 with metal fence post braces bolted to the bottom of the stringers. Oh, and if you have a mostly dry creek you need to cross, this was my solution. Need to mention that I wove cable back and forth through the blocks and tied to trees on both side to keep it from blowing out. By the way, the second bridge is only a walk bridge.
Edited by gtcsreg, November 23, 2013 - 09:38 AM.
  • IamSherwood, boyscout862, oldedeeres and 1 other said thanks
#51 IamSherwood OFFLINE
  • 8,395 Thanks
Posted November 23, 2013 - 07:12 PM
Well, I got the guard rails built today, and it's a darn good thing they work too.
It was kind of exciting for about 4 or 5 seconds. I tried going up first in low gear, but
just spun on the icy boards created by yesterdays flash freeze. So, I took a run
at it in 2nd highest gear. I got half way up, and the bald front tires on the ice
didn't do much good in keeping me straight, as the rears took turns spinning.
The front veered to the left guard rail, and there I was spinning away. I put the
clutch in, with the wheel turned a bit to the left, and before I knew it I was jammed
between the rails with the front right, and rear left tires. I shut it down, and left it in gear.
  So, now what to do? Well, get off and scratch your head I thought.
I wish I could have been a spectator watch me trying to get my fat arse, wearing a big snow
suit off that springy seat while at a 18 degree incline. I'm pretty sure it's 18 degrees
because it feels just like walking up the 4/12 pitch roof on my house to get my
Frisbee. After sucking my gut in and holding my breath to make myself
smaller and lighter, I leapt off. After that, it was pretty simple. I pulled the
front end to the center of the bridge, stood beside the tractor and pressed
down the clutch so it rolled off.
 I'm thinking I need better front tires, and maybe a tractor with diff lock. Elf has
diff lock, but slicks up front. Hmmm.
  • MH81, wvbuzzmaster, KennyP and 5 others have said thanks
#52 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,415 Thanks
  • 5,616 posts
Posted November 23, 2013 - 07:37 PM
Geez man you got snow up there, how much?
Rails look good and they must work, you tested them and they held.
  • KennyP and oldedeeres have said thanks
#53 IamSherwood OFFLINE
  • 8,395 Thanks
Posted November 23, 2013 - 07:42 PM
only about 2-3 inches.
Yeah, that was my plan when I raced up the bridge. Test them now.... :D  :(
  • boyscout862 and oldedeeres have said thanks
#54 oldedeeres OFFLINE
oldedeeres
  • 10,483 Thanks
  • 5,093 posts
Posted November 23, 2013 - 10:55 PM
That's your story and you're sticking to it? O.K., I'll buy that. Neat set of duals with chains though. In wet snow they really help.
  • IamSherwood said thank you
#55 HDWildBill OFFLINE
  • 8,984 Thanks
Posted November 23, 2013 - 11:13 PM
The bridge is really coming along Will!  Glad the rails held and everything is OK.  If it's OK with you just keep the white stuff up your way. :poke:
  • IamSherwood, boyscout862 and oldedeeres have said thanks
#56 KennyP ONLINE
  • 40,901 Thanks
  • 47,100 posts
Posted November 24, 2013 - 08:03 AM
May need some rougher surface on that ramp. Or put bike chains on the front tires with maybe a bit more weight up there to help them work! Glad the rails held! Looks wide enough for the FF.
#57 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted November 24, 2013 - 08:05 AM
I would rather go the safe route & use a winch! ......... Oh craps, I've become a wuss!   :rolling:
  • IamSherwood, KennyP and oldedeeres have said thanks
#58 IamSherwood OFFLINE
  • 8,395 Thanks
Posted November 24, 2013 - 08:24 AM
Plenty wide enough for the FF Kenny. Almost 6ft there.
If snow keeps coming, it won't be long before the snow will be too deep back there
for the GTs, unless they have skis on the front. That'll be a whole new adventure.
But in the mean time, the bike chains on the front, sounds like it might work.
:(  :( You called it. :(  :(
:rolling:  :rolling: :rolling:
  • olcowhand, KennyP and oldedeeres have said thanks
#59 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted November 24, 2013 - 08:27 AM
:nothingtoadd:
Next he'll suggest a brain bucket.................... :bigrofl:
#60 MH81 OFFLINE
  • 29,978 Thanks
Posted November 24, 2013 - 08:34 AM
I'm also thinking small chains for the front. Maybe even those cable ones you see in the magazines, but I think ones with x's instead of just crosses would be better... Something down the middle.
As for the out above :thank_you: I was laughing right out loud.
