I Built A Gt Bridge.
83 replies to this topic
#16 IamSherwood OFFLINE
  • 8,391 Thanks
Posted November 19, 2013 - 09:46 PM
Yep, beaming the end and using gravel should do the trick. Use fabric underneath it, it will be less likely to erode that way.
Yes, I have some, and I'll use it. thanks.
#17 collinmf12 OFFLINE
collinmf12
  • 114 Thanks
  • 197 posts
Posted November 19, 2013 - 09:48 PM
cool nice job :smilewink: :D
  • IamSherwood said thank you
#18 toomanytoys84 OFFLINE
toomanytoys84
    Aaron
  • 9,846 Thanks
  • 5,946 posts
Posted November 19, 2013 - 10:15 PM
I can't even get myself moving to build a new laundry room and you build a bridge!
  • IamSherwood, twostep and oldedeeres have said thanks
#19 Cat385B ONLINE
    HAZMAT CAT
  • 13,966 Thanks
  • 9,998 posts
Posted November 19, 2013 - 10:19 PM
Don't tell anyone, it's the shortest route to the bar is what I'm thinking...........
  • IamSherwood, KennyP and twostep have said thanks
#20 IamSherwood OFFLINE
  • 8,391 Thanks
Posted November 19, 2013 - 10:34 PM
Are you saying I should build another still up there? :bigrofl:
  • MH81 and twostep have said thanks
#21 Cat385B ONLINE
    HAZMAT CAT
  • 13,966 Thanks
  • 9,998 posts
Posted November 19, 2013 - 10:38 PM
Another? What happened to the first one?
#22 oldedeeres ONLINE
oldedeeres
  • 9,437 Thanks
  • 4,747 posts
Posted November 19, 2013 - 10:48 PM
Great bridge, wonderful view,----  where there's a Will, there's a way,     pun intended!
#23 IamSherwood OFFLINE
  • 8,391 Thanks
Posted November 19, 2013 - 10:52 PM
Can't remember. :rolling:
Hey, how about a zip line. Circled in red is one of the biggest white pines I've seen around here.
It's about 200 yards away. :D  That's a lot of cable to find. Hmmmm.
  • KennyP and oldedeeres have said thanks
#24 KennyP ONLINE
  • 38,221 Thanks
  • 45,860 posts
Posted November 20, 2013 - 07:01 AM
Very cool bridge, Will! You'll get something figured out for getting the GT's up there and down again. Maybe you need to change the name to "Big Rock GT Mountain".
#25 TAHOE ONLINE
TAHOE
  • 7,950 Thanks
  • 5,667 posts
Posted November 20, 2013 - 09:03 AM
That looks nice.
I know I would be in the creek over the side at some point :D
#26 Sawdust ONLINE
Sawdust
  • 5,642 Thanks
  • 3,359 posts
Posted November 20, 2013 - 09:28 AM
Looks real good Will. I did one similar several years ago. I dropped three locust trees across a small creek then added 2x8 planks. I had about 16" to fill on each end. I packed some rocks that were already there with some smaller stones & then got some crushed rock & filled the voids. This eventually packed like concrete. Make sure you dig out the top soil at each end before filling.
  • IamSherwood and oldedeeres have said thanks
#27 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted November 20, 2013 - 09:31 AM
He made a list.
  • IamSherwood, KennyP, oldedeeres and 1 other said thanks
#28 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted November 20, 2013 - 09:33 AM
That looks good and what a beautiful piece of land!  How do you ever convince yourself to go inside?
#29 boyscout862 ONLINE
  • 12,824 Thanks
  • 9,155 posts
Posted November 20, 2013 - 10:07 AM
You did a nice job on the bridge. There appeared to be a center pier, was that permantent? If not, I would put one in with splayed legs. The pier would greatly increase the strength and stiffness of the bridge. The splayed legs would prevent sway.
As an Army Engineer and a Town Engineer, I have built alot of bridges. The lack of railing makes me nervous but I realize that the bridge is for your private use and that Canadian laws are different. That being said, please put up a rail for your safety. I hope that you have many happy years of use of your bridge. Good Luck, Rick
  • IamSherwood, HDWildBill, oldedeeres and 1 other said thanks
#30 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted November 20, 2013 - 11:35 AM
Will, that looks like fun. Fun building it and using it.  We have a lot of white pine where I live and whenever any of them get cut down the home owners association tries to get the boles donated. We save up a few of them and then hire a bandsaw mill to cut them into planks which we use to make walkways over the wet spots in our nature trails. It's done in a similar way to what you've done with the bridge but in shorter spans and lower to the ground. We keep the width to 3 ft to keep ATV's off of the walking trails.
  • IamSherwood, HDWildBill and oldedeeres have said thanks
