I Built A Gt Bridge.
83 replies to this topic
#1 IamSherwood OFFLINE
  • 8,395 Thanks
Posted November 19, 2013 - 08:58 PM
First a bit of background.
When we bought this property(100 acres) in 2005, I promised my self I'd build a trail
up onto a large rock outcrop in the center of the property. The outcrop varies in height
on the sides, but is generally flat on top. It's about the size of a football field.
We call it "Big Rock Candy Mountain".
Here is the view to the south.
This is the only place that allowed access.
Last week I was back there gathering some deadfall firewood. The conditions
where right, so I went back the next day and started building the GT bridge.
First I cleared an approach, and then went and found a couple of straight
maples. About 14" at the butt, and 40' long.
I dragged the first one to location, and then using a cable and a couple of
snatch blocks, pulled it up and into location.
Then the second beam.
Then I found some dirt, and did a bit of ground work at the base.
That was day 1. Yesterday morning I milled up the decking until it got too
windy, so I got out of the bush. This morning I moved the deck materials to
site, and shored up the beams a bit. They had a bit of bounce to them.
I also had to trim the topside of the beams a bit, using an Adze.
It didn't take long from there to slap the deck down.
Victory :dancingbanana: I got to the top.
Of course, I had to go get a GT and try it. As you can see, I've got to build
some sort of an off ramp yet. Any ideas?
I've got some pick/axe/shovel work to do up top. I'm looking forward to
cruising the GTs around up there.
  • olcowhand, DH1, daytime dave and 18 others have said thanks
#2 AVB OFFLINE
AVB
  • 138 Thanks
  • 135 posts
Posted November 19, 2013 - 09:03 PM
Cool, nice job.
  • IamSherwood said thank you
#3 lyall OFFLINE
lyall
  • 2,179 Thanks
  • 1,577 posts
Posted November 19, 2013 - 09:05 PM
that is a great view
that bridge should last for many years
#4 MH81 OFFLINE
Posted November 19, 2013 - 09:06 PM
Will, that turned out fantastic and looks like a lot of fun.
for the ramp, do you have some flat rocks you could use.  obviously nothing unstable, but maybe some good mortar mix and some flatish rocks would work?
  • IamSherwood and oldedeeres have said thanks
#5 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted November 19, 2013 - 09:12 PM
Looks mighty fine Will. Your ambition always impresses me lol.
#6 olcowhand ONLINE
  • 42,464 Thanks
  • 31,824 posts
Posted November 19, 2013 - 09:15 PM
Will, I could sure use a guy like you here on the farm.  I like how you find solutions to most anything!   :thumbs:
  • IamSherwood, Team_Green and oldedeeres have said thanks
#7 DH1 ONLINE
DH1
    Electric Tractors
  • 5,379 Thanks
  • 5,611 posts
Posted November 19, 2013 - 09:16 PM
You've been busy looks great, maybe 1 day ET2 can climb up the ramp for a Photo shoot with all your Massey's together.
:thumbs:
  • olcowhand, IamSherwood and oldedeeres have said thanks
#8 HDWildBill OFFLINE
  • 8,978 Thanks
Posted November 19, 2013 - 09:21 PM
Hey Will, that didn't look like a GT at the top!  :poke:
Looks like a nice bridge and I think you will have a lot of fun with it.  On the top may be a good area for a picnic area with a fire place.
#9 Cat385B ONLINE
    HAZMAT CAT
  • 14,282 Thanks
  • 10,116 posts
Posted November 19, 2013 - 09:22 PM
Fantastic, Will! Like mentioned, use cement and rocks at the bottom. It will end up eroding if you don't.  At the top, use a few buckets of small rock. Rough, jagged stuff preferably so it locks together somewhat. You could use wood again, but make sure it gets lots of air, it could be a moisture trap.
Mulch would work, also. Not sure if you have any sticks, mulch, and bark laying around....... :rolling:
What size is that wheeler? They make a 2wd/4wd conversion for that, ya know.......
  • hamman, IamSherwood, twostep and 1 other said thanks
#10 IamSherwood OFFLINE
  • 8,395 Thanks
Posted November 19, 2013 - 09:25 PM
:thumbs:
Yes, bring ET up here. Do it soon. Before winter gets here. We'll do a nice trail ride.
  • DH1 said thank you
#11 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted November 19, 2013 - 09:28 PM
Well done!  :thumbs:
Geno
#12 olcowhand ONLINE
  • 42,464 Thanks
  • 31,824 posts
Posted November 19, 2013 - 09:32 PM
Oh yes, I can imagine that would be a huge pucker factor going up that bridge all snowy & icy!  EekSmiley.png
#13 IamSherwood OFFLINE
  • 8,395 Thanks
Posted November 19, 2013 - 09:37 PM
Absolutely, I'll be building something up there. I plan on harvesting some logs this winter for that.
The butts of the beams are against a rock shelf, and I'm going to cap off the fill with "A" gravel. That
should hold up.
Yep, that's it. I can cart up some Type 2 gravel in recycle bins. I won't take Kubota up the bridge.
I'll contain it from getting pushed under the bridge by putting a 2 x 6 treated board across the ends
of the beams. That should work, right?
What size is that wheeler? They make a 2wd/4wd conversion for that, ya know.......400 Foreman.
  • HDWildBill and oldedeeres have said thanks
#14 hamman ONLINE
hamman
    Homelite Owner Extraordinaire
  • 6,580 Thanks
  • 2,906 posts
Posted November 19, 2013 - 09:40 PM
Wow, that is a great bridge. You have some beautiful property there. Keep us posted. Thanks. Roger.
#15 Cat385B ONLINE
    HAZMAT CAT
  • 14,282 Thanks
  • 10,116 posts
Posted November 19, 2013 - 09:44 PM
Yep, beaming the end and using gravel should do the trick. Use fabric underneath it, it will be less likely to erode that way.
  • IamSherwood, HDWildBill and oldedeeres have said thanks
