Replacing Alt.- Fan Belt On 332 J. D.
7 replies to this topic
#1 Texas Deere and Horse ONLINE
  • 14,883 Thanks
  • 15,514 posts
Posted November 17, 2013 - 11:03 PM
OK, so I needed to change the fan/Alt. belt on the 332 JD that I am going to sell. In order to do that I had to pull the drive shaft and get the shaft unbolted, the Radiator had to be pulled.
I first had to remove the air cleaner, then get the fan shroud unbolted. Once I got that done and unhooked the hoses I could get the radiator out  then I could pull the fan off the water pump for more room to work. The hardest part was getting the bolts out of drive shaft coupling, they were rusted in pretty hard and there is not a lot of room to work in there.
IMG_20131117_145129_693.jpg IMG_20131117_142539_031.jpg IMG_20131117_120014_842.jpg IMG_20131117_141104_321.jpg
The rubber coupler looked like it was in new condition, Thankfully!
Got everything back together and it's up and running.
A little more cleaning up and few more things to check over and it will be ready to sell.
  • Alc, JDBrian, Dieselcubmike and 1 other said thanks
#2 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted November 17, 2013 - 11:13 PM
Looks like you were busy Brian! It really kills me when the tractor makers were installing these diesel motors in backwards to run off the crank. Do they not realize how hard they are on parts? Maybe its because of my pulling back ground when is see things like this :deadhorse:
  • Texas Deere and Horse and JRJ have said thanks
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted November 18, 2013 - 06:52 AM
The diesel engine was a addition to a tractor designed for  the gas engine lineup and it shows. Thats a lot of work to change a fan belt.
#4 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted November 18, 2013 - 01:47 PM
For anyone with a JD diesel:  when planning on changing any belts contact Brain for he is our residence man on this subject along with many others.
Dick
  • Texas Deere and Horse and KennyP have said thanks
#5 Cat385B OFFLINE
    HAZMAT CAT
  • 14,369 Thanks
  • 10,138 posts
Posted November 18, 2013 - 10:34 PM
I would prefer you cleaned and touched up the paint on the frame before you bring it up here for me. But for $500, I'll let it slide.
#6 Texas Deere and Horse ONLINE
  • 14,883 Thanks
  • 15,514 posts
Posted November 18, 2013 - 10:36 PM
OK Cat, I'll discount the price to you to $1,500.00 after all it is Green !! :smilewink:
#7 Cat385B OFFLINE
    HAZMAT CAT
  • 14,369 Thanks
  • 10,138 posts
Posted November 18, 2013 - 10:38 PM
$1,000 for delivery? Are ya putting it on the lowboy?
#8 Alc OFFLINE
  • 7,221 Thanks
  • 7,576 posts
Posted November 19, 2013 - 06:26 AM
Brian could one of those " link " belts worked on something like this ?  It looks like as much work as changing belts on a PK
