Peerless 2300 Series Transaxle
11 replies to this topic
#1 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted November 17, 2013 - 08:13 PM
Can you still buy gears for the transaxle outta my speedex its a 4 speed pretty sure its a 2300 series same thes it the jd 112s and what happens is it jumps outta 4th gear and sometimes 3rd well actually now its getting worse 3rd a good bit of the time 4th i can even run it what do you think this would be??  i got till spring to fix it  but id like to plow this winter with it
Edited by superspeedex, November 17, 2013 - 08:58 PM.
#2 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted November 17, 2013 - 08:30 PM
Probably can still get them, I may have them in stock.  If you get a model number I can check for certain.
Ben W.
  • superspeedex said thank you
#3 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted November 17, 2013 - 08:33 PM
ill try and get numbers tommorow do you have any idea of what the problem is thought gears springs bearings
  • superaben said thank you
#4 DH1 ONLINE
DH1
    Electric Tractors
  • 5,452 Thanks
  • 5,621 posts
Posted November 17, 2013 - 09:08 PM
Sounds like maybe the detent is not holding it in gear. 3rd + 4th are on the same shifter fork, use the same detent spring and ball.
I've found broken detent springs, usually on the R - 2nd - 1st shifter fork.
  • superaben, superspeedex and Leonard VanCamp have said thanks
#5 lyall ONLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted November 17, 2013 - 09:18 PM
when you take the transaxle apart - check it for the detent spring like DH1 stated
then check the gears for wear before you but any gears
when you put the transaxle back together you should get a case gasket
while you have it apart also check the axle seals and o-rings
most if the time I replace the axle seals and o-ring too
#6 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted November 17, 2013 - 09:27 PM
yea 4th has been fading in the past year  but it dont have that slip or clunk i wanna say to keep it in gear so s that what the detent spring is?? can i by just a detent spring  and i need to get a pulley bearing as well seals aint leaking but i may get them any way
#7 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted November 17, 2013 - 10:02 PM
Follow Doug's advice.
When you have the model I should have an IPL we can study and see what is missing.
Ben W.
#8 lyall ONLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted November 17, 2013 - 10:04 PM
your should replace both springs
if the seals are good you do not have to are this time
if you do not a manual for the transaxle you can download it from
GardentratorTalk manual section
there are 2 manuals and a parts list that should help you
http://gardentractor...ission-manuals/
Tecumseh Technican's Handbook
Tecumseh/Peerless 2300 Series Parts List
Tecumseh/Peerless 2300 Transmission Repair
to make it easier to work on the transaxle - I leave the wheel the side that the case bolts are not on.  I flit the transaxle up on the wheel so that the transaxle is vertical.  that way when you open the case all the gears do not fall out,  they stay in place.  and when you put it back together it is easier.
Edited by lyall, November 17, 2013 - 10:06 PM.
  • Alc and superspeedex have said thanks
#9 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted November 17, 2013 - 10:07 PM
yep ill get the number tommorow
#10 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted March 29, 2014 - 01:07 PM
Hey got it apart the 3rd and 4th rod move way free er than 1n2 and reverse side i guessing spring cause gears are fine
#11 Slugbug OFFLINE
Slugbug
  • 1 posts
Posted March 13, 2018 - 01:10 PM
On my Peerless 2300 series transaxle  I'm unable to find the exact model # that is supposed to be engraved in the casing. I need to order several gears. Also there is no model # tag attached to casing.  The transmission goes to a 1968 Ford/Jacobson 120 garden tractor. Is there any other way to get the exact model number to look up the parts?
#12 Bolens 1000 ONLINE
  • 15,434 Thanks
  • 18,287 posts
Posted March 13, 2018 - 05:07 PM
maybe with some pics we may be able to id the parts
