Wanted
Wanted, Bottom Of Flo- Jet Carb.....
8 replies to this topic
#1 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,361 Thanks
  • 2,838 posts
Posted November 16, 2013 - 06:53 PM
Lower half of Flo - Jet 2 piece carb. Looking for three (3)  for three engines I have that needs carbs. These are for B&S 326431 engines. Don't have to be clean just need to be rebuildable with good threads for the high speed jet ( emulsion tube). Have tried ebay and CL and all the local ( within 60miles) small engine places with out any luck. Don't need whole carb just the lower half.  Thanks. Roger.
#2 jabelman OFFLINE
jabelman
  • 2,163 Thanks
  • 1,559 posts
Posted November 16, 2013 - 08:37 PM
Hi roger
I was able to find new lower halfs with manual choke online they run about 40 to 50 bucks. I recently got a new flo jet #295857 online for not much more. All the used ones i saw at swap meets and on ebay they seemed really overpriced for a few bucks more i went new
  • Texas Deere and Horse and hamman have said thanks
#3 hamman OFFLINE
hamman
  • 6,361 Thanks
  • 2,838 posts
Posted November 16, 2013 - 09:05 PM
What is the part # and where did you find the lowers? I've been cking ebay but haven't seen any thing. Thanks. Roger.
#4 jabelman OFFLINE
jabelman
  • 2,163 Thanks
  • 1,559 posts
Posted November 16, 2013 - 09:11 PM
Lower 1/2 man choke 295860 or 299170
  • hamman said thank you
#5 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted November 16, 2013 - 09:24 PM
295860 and 299170 are for the L shaped 3 bolt, Roger is looking for a 4 bolt U shaped.  I didn't realize that the 3 bolt lower halves were on eBay, though, thanks for posting!
Those daggone threads strip too easy.  If you wanted stripped lower halves, I could send you a boxful.  :wallbanging:
Roger, I have one complete good salvage carburetor that I would get rid of.
Part number 391069 is what you want:
http://www.ebay.com/...=item35c9e4c3fa
You can get a complete carb new for $100 on eBay, so don't spend too much.
I can check my salvage guys if you want.  They might have something for you.
Ben W.
#6 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted November 16, 2013 - 09:28 PM
FWIW, I can get the same 391069 for $55 from my distributor, new from Briggs.
Salvage would be probably around $30, and I would consider spending the extra $20 to guarantee that the nozzle seals.  OId ones warp over time.
Ben W.
#7 hamman OFFLINE
hamman
  • 6,361 Thanks
  • 2,838 posts
Posted November 17, 2013 - 09:39 AM
Thanks guys. Being on a limited budget I was hoping to get some salvaged ones to clean and put back together for these engines. The ones on ebay for $50 look good. If I can't find some old ones I will have to break down and buy them. I need to get these old GTs running next spring. Thanks again. Roger.
  • superaben said thank you
#8 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted November 17, 2013 - 01:07 PM
The problem with salvage is that anyone who has one knows that the problem these carburetors always have is those stripped threads.  They know they have the key to fixing your machine.
Its aggravating.
Ben W.
#9 drbish ONLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,358 posts
Posted November 17, 2013 - 01:27 PM
I have one maybe 2 off them,maybe 3 i would have too dissasemble them as they are complete carburetors
PM me if interested
Just checked outside ,I have 2 of them but could get another Friday from the graveyard
Edited by new restorer, November 17, 2013 - 01:59 PM.
