Got Bush Hog D4-10 Home From N. Tx. Picture Heavy.
bush hog d4-10 bh d4-10 10hp bushhog tractor
82 replies to this topic
#61 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted May 15, 2014 - 11:00 PM
I got the PTO clutch off and started on removing the flywheel. Going to fab a puller as the one I normally use doesn't bolt up as well as I would like.
When you start to take the PTO clutch off make sure you remove both sets of set screws in the clutch housing, I almost missed that and Daniel put me on the right path.The second set holds the first set from backing off the shaft.
This engine was out in the weather for long time before I got it. So I soaked all the set screws overnight with PB blaster. I then got a needle nosed long punch that would fit inside the set screw and gave it 3 or 4 good taps with a hammer.
The set screw wouldn't budge so I used a small brazing tip on the torch to heat up the clutch housing.
As soon as I got done heating them up, they broke loose.
I didn't take a picture but I did use a bottoming tap to clean the threads before I backed the screws all the way out. Here is the clutch assembly all apart and off the engine.
  • olcowhand, IamSherwood, KennyP and 1 other said thanks
#62 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted May 16, 2014 - 10:05 AM
Got the flywheel off and I guess this engine was always an external coil engine.
#63 olcowhand OFFLINE
  • 40,350 Thanks
  • 31,170 posts
Posted May 16, 2014 - 10:40 AM
Well, at least you now know for sure!
#64 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted May 21, 2014 - 09:18 PM
Not had a lot of time to work on this but I wanted to share a few things I have learned so far.
First is the Throw Out bearing, I ordered a PK throw out bearing and it came in. It is almost identical to my original bearing that came out of the clutch. The new bearing is about .030" thicker then the old one, I believe this to be caused by wear on the old one were it rides on the pressure plate fingers.
IMG_20140519_155818_742.jpg IMG_20140519_155906_503.jpg IMG_20140519_155916_233.jpg
Next item is the Front pressure plate. I have 2 of them of of the tractors and they are different. I has a lot more shoulder towards the engine then the other one does. Also the long one has 3 set screw and the other one doesn't, only 2 set screws.
Lastly, the clutch output shaft is bent on this clutch so I will have to use the spare shaft out of the other tractor.
  • olcowhand, IamSherwood and sacsr have said thanks
#65 olcowhand OFFLINE
  • 40,350 Thanks
  • 31,170 posts
Posted May 21, 2014 - 09:25 PM
Yes Brian, mine have the short clutch plate hub, and use a spacer.
#66 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted May 21, 2014 - 09:29 PM
The long one was on the WIS. TRA-10-D, the short one was on the replacement Kohler engined tractor. I thought maybe that the short one had been machined to fit. Thanks Daniel.
  • IamSherwood said thank you
#67 KennyP ONLINE
  • 37,426 Thanks
  • 45,465 posts
Posted May 22, 2014 - 05:58 AM
Good to see some progress here! End of school year is always a busy time.
#68 olcowhand OFFLINE
  • 40,350 Thanks
  • 31,170 posts
Posted May 22, 2014 - 07:46 AM
Had my spare clutch handy for a pic.
  • Texas Deere and Horse and sacsr have said thanks
#69 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted May 25, 2014 - 05:56 PM
I received he new clutch fingers and springs Friday and I think they will work just fine. here are a couple photos of the old and new fingers and springs
IMG_20140524_080652_167.jpg IMG_20140524_080753_691.jpg IMG_20140524_080819_230.jpg .
  • sacsr said thank you
#70 LPBolens OFFLINE
LPBolens
  • 1,348 Thanks
  • 961 posts
Posted May 25, 2014 - 07:05 PM
attachicon.gifIMG_20140524_080652_167.jpgattachicon.gifIMG_20140524_080753_691.jpgattachicon.gifIMG_20140524_080819_230.jpg.
Where did you get them?
#71 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted May 25, 2014 - 09:10 PM
There is a guy on Ebay that sells PK parts and so far it appears that they are the same parts in both clutches.
  • LPBolens and KennyP have said thanks
#72 olcowhand OFFLINE
  • 40,350 Thanks
  • 31,170 posts
Posted May 25, 2014 - 09:12 PM
Were the original springs visually sacked any when stood beside the new springs?
#73 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted May 25, 2014 - 09:25 PM
They didn't look any shorter, but I didn't really inspect them that closely. I may do a compression test on both to see how they compare.
#74 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted July 09, 2014 - 09:31 AM
Got the chance yesterday to do a little more work on this engine and clutch set up. I got the clutch pack all back together with new springs and fingers and back on the crankshaft. Still have to install new bearings on the output shaft and throw out bearing. I used the output shaft to align the clutch pack.
IMG_20140708_154508_395.jpg IMG_20140708_154518_552.jpg IMG_20140708_154533_052.jpg IMG_20140708_160424_413.jpg
  • olcowhand, KennyP, Titus and 2 others have said thanks
#75 olcowhand OFFLINE
  • 40,350 Thanks
  • 31,170 posts
Posted July 09, 2014 - 11:05 AM
Glad you got some "Hog Time" Brian.  I've not gotten any shop time the last several days.
Also tagged with one or more of these keywords: bush hog, d4-10, bh d4-10, 10hp, bushhog tractor
