Need Help Building Ramps
27 replies to this topic
#16 olcowhand ONLINE
  • 40,351 Thanks
  • 31,170 posts
Posted November 16, 2013 - 02:55 PM
Marty, I wouldn't want to use those rails myself.  One reason is strength, the other is how they will be slick & offer little traction, especially if the slightest bit damp.
  • HDWildBill said thank you
#17 TAHOE ONLINE
TAHOE
  • 7,811 Thanks
  • 5,611 posts
Posted November 16, 2013 - 08:46 PM
Thanks
I know all about welding galvanize or not to weld it.
I've actually ran a truck up on them to get it off ground and they held. They can collapse easily though if any side forces are put on them. I was going to bolt on straps across bottom for support.
Maybe I will just abandon these and modify my 5' wide gate that goes on my smaller utility trailer, can't use it on there any more, just sitting in barn. I could mount it on the back of he big trailer, add some extra strengthening supports and just leave it on. I never haul cars anymore on trailer anyway so it could stay on all the time.
#18 olcowhand ONLINE
  • 40,351 Thanks
  • 31,170 posts
Posted November 16, 2013 - 09:50 PM
The beauty of the wide gates is you cannot slide off it, and it can't slide off your trailer.  If it did bend which is almost impossible with a GT, you'd still have tires firmly on the bent gate.
  • TAHOE said thank you
#19 MH81 OFFLINE
Posted November 17, 2013 - 03:45 AM
Never gave the slippery a thought. Yeah, that would be a little spooky on a rainy day or a dewy morning or even some snow...
I think the gate would do you well
#20 TAHOE ONLINE
TAHOE
  • 7,811 Thanks
  • 5,611 posts
Posted November 17, 2013 - 01:24 PM
I was loading my tractor last  my winch mount/snow blade. My Sears has loaded aggs, 33# wheel weights, winch/mount with snow blade and my 200#'s so probably pushing 1000#'s.  Cold wet snow covered tires on a wet board and she slid right off the side, when the  rearend landed on middle of just 1 board.... SNAP!!!! I currently have 2x8, ramps and this is why I want to go with something sturdier.
My gate was custom made  for my trailer by a coworker, but due to the trailer being a tilt trailer and balanced in the middle, the extra 80-100#'s or so of gate makes trailer a very bad tail wagger so I can not use it, what a waste it was for that trailer. I would definitely have to beef it up to make sure it wouldn't bend and it's only 4' tall made with only angle/light weight expanded metal, guess I can figure something out.
#21 HDWildBill OFFLINE
  • 8,975 Thanks
Posted November 17, 2013 - 01:33 PM
Why not go to HF and buy a set of ramps?  I've been seeing a lot of 25% off coupons lately so if you used one of them you could buy a set for less then what it would cost to make or modify something.  Plus they are rated any where from 1000 to 1500#.
#22 TAHOE ONLINE
TAHOE
  • 7,811 Thanks
  • 5,611 posts
Posted November 17, 2013 - 01:44 PM
In the famous words of the "home boy shopping network"
No money, no money, no money!
I really want something to handle minimum of 1500 or more. Once I get the Massey running with loaded tires and 150# extra wheel weights, rear implement and possible front small FEL, it will be pretty heavy. Probably have to go to my car ramps then.
I may just modify my car ramps, but they are so heavy already. I could make them semi-permanent so the are mounted and just lifted like the tailgate or those on bigger trailers.
#23 lyall ONLINE
lyall
  • 2,020 Thanks
  • 1,525 posts
Posted November 19, 2013 - 09:36 PM
to make the ramps fit together I would get a 1/4" plate steel that fits inside the uprights of the ramps and it should be a minimum of 2 foot long.  with half of the steel plate inside the ramps sides, bolt the plate to the ramps ( both side of the ramp)  - the other ramp should slide together making a long ramp.  you do not have to blot the plate the the second part of the ramps.  But if you think it might came apart, you can put a removable pin in one side of the second ramp
you should be able to take the ramps apart for storage or transport
note I would not put 3 section together to make a long ramp - it would be a bad idea
I used a 2x12 - 12' long for my ramps.  I bolted a 1-1/2" x 1-1/2" angles on both sides on the ramps
I have had no problem with them with my JD 214 with and tiller on or with my JD 212 with snowblower and cab
  • Sawdust said thank you
#24 Alc ONLINE
  • 6,742 Thanks
  • 7,396 posts
Posted November 20, 2013 - 06:37 AM
We got this ramp for loading my wife's little motorcycle in the back of the truck when we go camping , also worked great for the DB , you might get some ideas from this site they have a lot of different styles . I can take close-ups of the hinge point if you want .
 http://www.discountr...rcycle-ramp.htm
If you look close they are 3 ramps  2 small and 1 a little bigger so it can be used different ways
Edited by Alc, November 20, 2013 - 06:40 AM.
  • MH81 and TAHOE have said thanks
#25 TAHOE ONLINE
TAHOE
  • 7,811 Thanks
  • 5,611 posts
Posted November 20, 2013 - 08:58 AM
yea, I've toured that website a few times, plenty of eye candy on there.
I had thought about just adding some long angle to teh sides of some 2x10's or so, but....$$$$$
I would like to buy a pair of ramps, HF, Discount, etc, but.....$$$$$
I'm just trying to utilize what I already have and grabbing scrap out of the  pile to use.I have those short ramp pieces and i have a gate already made so trying to use them without spending too much more money to adapt.
lyall, I kind of like that idea, not sure if I could get it to work right, but sounds interesting.
Thanks
  • lyall said thank you
#26 Sawdust ONLINE
Sawdust
  • 5,562 Thanks
  • 3,335 posts
Posted November 20, 2013 - 09:46 AM
I know I first gave you a discouraging comment at first about not being able to get a good joint on these. I like you try so hard to use what I have & most the time I succeed. I've been giving your project a lot of thought....I like a challenge. What I had in mind was like Lyall mentioned. These plates inside the sides of your ramps would bare the load at the joint. You could slide a rod like a removable pin through each end of the plates. I have a pair of 2x10 treated lumber 7' long that are over 20 years old. I know for a fact even though lumber is still rated it by far isn't what it use to be. We are forced to buy lumber from other countries & some are hybrid & young growth. Keep us up dated.
#27 olcowhand ONLINE
  • 40,351 Thanks
  • 31,170 posts
Posted November 20, 2013 - 12:49 PM
I just worry how those metal pieces can twist easily.  And like even you said Marty, can collapse if things aren't just right.  I just can't offer advice on how to use them, as I would feel at least partially to blame if I did, then you got hurt.  I wanna see you at some plow days again....with all your joints/limbs intact!  :smilewink:
#28 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted November 20, 2013 - 02:34 PM
If I were set on use these (which with some bracing I see no reason not to) I would hinge them something like what I've sketched up. Personally, I HATE messing with galvanized steel but I understand the "use what you have" way of doing things.
Edited by twostep, November 20, 2013 - 02:36 PM.
