Inside The Transaxle Of A Model 15 Waterloo
waterloo walk behind
9 replies to this topic
  • 2,348 Thanks
  • 1,502 posts
Posted November 15, 2013 - 09:28 PM
Since I didn't get any positive replies to my request for photos or a parts list for the innards of a Model 15 Waterloo, I thought I'd take some while I had mine apart.  Hope it helps someone else down the line.  Check out the spiral pattern on the middle gear!  Thankfully it was just in the grease.
inside 1.jpg inside 2.jpg inside 3.jpg inside 4.jpg inside 5.jpg inside 6.jpg inside 7.jpg inside 8b.jpg inside 8.jpg
  • DougT, Alc, JDBrian and 5 others have said thanks
#2 Mike Unwin OFFLINE
Mike Unwin
  • 405 Thanks
  • 304 posts
Posted November 17, 2013 - 02:58 PM
Hi, What are you going to refill it with ? Could you when you have time post a picture of your cultivator please ? Thanks Mike
Edited by Mike Unwin, November 17, 2013 - 03:01 PM.
#3 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted November 17, 2013 - 06:17 PM
It had nothing in it when I opened it, but I was thinking I'd use SAE30.  That's what was in my David Bradley.  I have some photos of the cultivator from a while back.  If there is a part you'd like to see better, I have it in the shop for the winter.  I also have a model 40 with cultivator.  It is much larger & has a different hitch.
I'd like to see your plow & hitch mechanism, if you could post some shots in your Model 20 posting.
  • Alc, trowel and Mike Unwin have said thanks
#4 Mike Unwin OFFLINE
Mike Unwin
  • 405 Thanks
  • 304 posts
Posted November 17, 2013 - 09:34 PM
Okay Monday I will get the pictures .
#5 Alc ONLINE
  • 7,220 Thanks
  • 7,575 posts
Posted November 18, 2013 - 06:45 AM
Are the worn parts repairable ?  Would they would be hard to find if not ?
  • trowel said thank you
#6 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted November 18, 2013 - 08:19 AM
None of the parts are worn out or damaged beyond repair (except the oil seals).  There is some slop in the bushings and fittings, but nothing intolerable, given that it is an agricultural implement.  It may not be a show room condition restoration candidate, but it will survive to run another day.
  • Alc and trowel have said thanks
#7 Mike Unwin OFFLINE
Mike Unwin
  • 405 Thanks
  • 304 posts
Posted November 18, 2013 - 09:56 AM
I think your cultivator is correct seem to recall that " A " shaped frame,now here is another but it is rectangular like my Empire.Did they change designs or  is this a cultivator from a small Iron Horse Empire behind this Model 20 ?
Edited by Mike Unwin, November 18, 2013 - 09:57 AM.
#8 Mike Unwin OFFLINE
Mike Unwin
  • 405 Thanks
  • 304 posts
Posted November 18, 2013 - 10:00 AM
Well yours looks like this one....http://www.simplicit...com/page-8.html
Hard to find much info on Empires and Waterloos really wasn,t that long ago they were built.Never seen a owners manual for either.
#9 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted March 30, 2014 - 12:27 PM
I found a manual for the 40 that says to use SAE 140 oil in the gear case.
  • trowel and Mike Unwin have said thanks
#10 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 30, 2014 - 03:12 PM
Cool, thanks for the inners, that spiral on the grease is unique, the DB gear box is a chain case, never had to replace but heard it is a pain.
The Speedex and some of the Simplicity gear boxes was like your Waterloos, all gears.
Also tagged with one or more of these keywords: waterloo, walk behind
