Twist On The Trailer Idea
9 replies to this topic
#1 Bob IN OFFLINE
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted November 14, 2013 - 08:57 PM
I picked up an allstate one wheeled trailer that mounts to a car. It was sold in the 50s. Like the one in the picture. I am considering building one for the back of a gt. Any thoughts? Any factory type trailers like this? I thought it would be useful.
  • earthgrinder, Alc, hamman and 5 others have said thanks
#2 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted November 14, 2013 - 10:01 PM
I had something similar to that on a cub, mounted to the rear and had two swivel wheels on it
  • Alc, hamman and JRJ have said thanks
#3 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted November 14, 2013 - 10:35 PM
I have a home-built one with two swivel wheels that connects to the lower arms of the 3-pt hitch.
One problem in the design - being connected tot he lower 2 arms, it will tip up or down without warning.
Backing up is a mind bending event.  It should be as easy as backing up without a trailer, but if you are used to backing a trailer you will be all over the place.  Another event to watch out for is the trailer will swing in the opposite direction when you turn going forward.
  • Alc and JRJ have said thanks
#4 Jlaws OFFLINE
Jlaws
  • 556 Thanks
  • 368 posts
Posted November 14, 2013 - 10:41 PM
If you had a Cat 0 three point on your GT , that be a good attachment point for that type of setup . It would also be a lot easier to back up than a regular trailer ........hummmmm
  • JRJ said thank you
#5 KC9KAS OFFLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted November 15, 2013 - 05:13 AM
A school teacher friend of mine had a 1 wheel trailer back in the late 60's early 70's.
It was quite a conversation piece!
Remember 1 time going across a 1 lane bridge with additional boards where the vehicle tires ran. The 1 wheel trailer dropped down, then bounced back up (rather high) when we exited the bridge.
They make 1 wheeled trailers to pull behind motorcycles too!
  • Alc, JRJ and Bob IN have said thanks
#6 grnspot110 ONLINE
grnspot110
  • 4,324 Thanks
  • 2,697 posts
Posted November 15, 2013 - 07:09 AM
I built this two-wheeler to fit the sleeve hitch:
Lifting it when empty make it easier to back up to water hydrant:
I had the big casters on hand, angled them back 45 degrees with a piece of angle iron.
Lowell
Edited by grnspot110, November 15, 2013 - 07:12 AM.
  • Alc, KennyP, sacsr and 3 others have said thanks
#7 Sawdust ONLINE
Sawdust
  • 6,158 Thanks
  • 3,554 posts
Posted November 15, 2013 - 10:16 AM
Although they were neat in their day I think the typical two wheel would be better. You would have limited weight capacity, tipping & problems backing up.
#8 earthgrinder OFFLINE
earthgrinder
  • 1,149 Thanks
  • 506 posts
Posted November 17, 2013 - 06:00 PM
I saw one of those at Rough & Tumble a few years back mounted on an old car like your photo shows.
#9 Talntedmrgreen OFFLINE
  • 3,290 Thanks
  • 2,316 posts
Posted November 24, 2013 - 08:20 AM
JrCo makes the 2-wheel swivel caster style carts, that are often used with vac collectors.  I had one and loved it....makes working in and around tight areas simple without jack knifing.  If your hitch is stout enough, I'd think a single caster would work.
#10 grnspot110 ONLINE
grnspot110
  • 4,324 Thanks
  • 2,697 posts
Posted November 24, 2013 - 10:44 AM
I saw a new two-wheeled trailer on a newer style car this week, it had a gooseneck under the rear bumper for the hitch.  Whatever was one it had a fitted cover, possibly an electric wheelchair.  ~~  Lowell
