Waterloo Model 15 Transaxle Question
2 replies to this topic
  • 2,331 Thanks
  • 1,498 posts
Posted November 14, 2013 - 06:51 PM
I've brought a Waterloo Model 15 into the shop as a winter project.  My current problem is that the input shaft is moving sideways & throwing the drive belt off the pulleys.  Anyone have a parts manual, or a picture of innards of this thing?  Any guesses as to what I might wrong find inside?
before 1.JPG before 2.JPG before 3.jpg before 4.jpg before 5a.JPG before 5b.JPG before 6.JPG
#2 Bob IN OFFLINE
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted November 14, 2013 - 07:09 PM
Im not sure what your going to find. I have a simplicity d walk behind with a similar set up, it has a lot of wear like that to.  I imagine there has to be some way you could shim that up. May not be the best fix but it would work.
  • Alc and New.Canadian.DB.Owner have said thanks
#3 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted November 15, 2013 - 09:22 PM
Well, turns out the problem wasn't inside.  Some numpty (yup, me) replaced a missing set screw with a grease fitting.  Didn't figure it out until I got it apart & found the imprint.
  • Bob IN said thank you
