14.5 Briggs Rider Mower Turns Over One Rev And Stops
7 replies to this topic
#1 jimjohnson OFFLINE
jimjohnson
  • 3 Thanks
  • 7 posts
Posted November 14, 2013 - 12:46 PM
Hello all I've got briggs motor that pull plug out will turn over just fine put plug in and wont turn over more than once like weak starter removed starter dissasembled cleaned tested seems to work fine re-install does same thing there isn't any load on it does anyone have an idea of what tk check
  • Dieselcubmike said thank you
#2 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted November 14, 2013 - 12:50 PM
Havent worked on a gas motor for sometime but id be glad to welcome you if I haven't already :wave:
#3 jimjohnson OFFLINE
jimjohnson
  • 3 Thanks
  • 7 posts
Posted November 14, 2013 - 12:54 PM
How do and thanks am new not sure where to post so forgive and point in right direction please ty jim
#4 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted November 14, 2013 - 01:27 PM
Not problem give it some time and before long youll have plenty of response :thumbs:
#5 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted November 14, 2013 - 01:34 PM
If its the OHV engine, check the valve adjustment. Mine did the same thing until I adjusted the valves correctly. There is a decompression bump on the cam shaft, if the valves are too loose, the decomp doesn't work.
#6 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted November 14, 2013 - 03:41 PM
Ditto on the valve adjustment.  I would also look to see if the valves are even moving & then for carbon deposits on the head.
#7 CRFarnsworth ONLINE
CRFarnsworth
  • 4,664 Thanks
  • 2,140 posts
Posted November 14, 2013 - 04:58 PM
What he said.            Rick
#8 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted November 14, 2013 - 06:29 PM
Check the decompression like has been said.  That's probably the issue.  Do you have good strong battery cables?  Sometimes you can get enough to spin an engine without the spark plug with crummy cables, but with compression you can't get er done.  I've been there and seen that on my machines.
Ben W.
