I Hauled Home A Couple More Wheel Horse's
raider 12 and a 1077
7 replies to this topic
#1 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,643 Thanks
  • 1,318 posts
Posted November 12, 2013 - 11:19 PM
The 1077 is a fairly rough roller but it is also my favorite style ( 66-67 long frame ) WH tractor.The Raider 12 has been redone and was just used for shows so it does not have the mid Tach or the mule drive setup on it and the rear hitch is missing. The biggest issue with the tractor is that the big block K301 Kohler 12HP was replaced with a K181 8HP small block Kohler. The engine sits to low for the belt guard to fit it right,so i will have to raise the engine an inch or so. Then i will have to put the right drive pulley on it. As it sits now it won't shift because the belt guard won't stop the belt when you push the clutch in. Overall this is a very nice tractor.
  • Texas Deere and Horse, Cvans, boyscout862 and 2 others have said thanks
#2 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,643 Thanks
  • 1,318 posts
Posted November 12, 2013 - 11:23 PM
I played with some different exhaust ideas a few days ago. These are mufflers that a buddy made for me.
  • Texas Deere and Horse, Cvans and farmer john have said thanks
  • 14,888 Thanks
  • 15,514 posts
Posted November 12, 2013 - 11:24 PM
Jim, I would be worried about the muffler doing damage to the hood decal. Nice haul, maybe you will come across a gook K301 to drop back in her!
  • rustyoldjunk and farmer john have said thanks
#4 Cvans OFFLINE
  • 7,289 Thanks
  • 6,377 posts
Posted November 12, 2013 - 11:32 PM
I like the older Wheel Horse tractors like yours. That a nice looking machine.
#5 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,643 Thanks
  • 1,318 posts
Posted November 12, 2013 - 11:37 PM
A few more pic's. The Raider has rear wheels off of another brand and the offset makes it more narrow in the rear But i have a cure. I have some with a better offset to set them out a little more with AG's on them !
  • Cvans and farmer john have said thanks
#6 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,643 Thanks
  • 1,318 posts
Posted November 12, 2013 - 11:40 PM
I agree Brian and i really don't like a stack set up on this style of tractor,i think it interferes with the clean lines of the long narrow hood. I will most likely come up with a under hod or out of the way setup.
  • farmer john said thank you
#7 farmer john OFFLINE
farmer john
  • 1,830 Thanks
  • 924 posts
Posted November 13, 2013 - 12:08 AM
you brought home some nice gts, wish i lived in the south where the weather does not crap up all your stuff
  • rustyoldjunk said thank you
#8 Cvans OFFLINE
  • 7,289 Thanks
  • 6,377 posts
Posted November 13, 2013 - 11:17 AM
If you should decide to put duals on it those wheels would be nice on the inside. Otherwise your right about changing them and looking better.
