B&s Part Number
2 replies to this topic
#1 Bob IN OFFLINE
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted November 12, 2013 - 06:21 PM
I have two briggs and Stratton part numbers. 270026 and 298060. First one is a box of diaphragms, I understand there briggs carb diaphragms but what hp do the fit? The last is a condenser it looks like an electronic ignition module.  Does it require points still?
#2 drbish ONLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,357 posts
Posted November 12, 2013 - 07:48 PM
check here just enter your part number
http://www.briggsand...e/193401001099/
this is the condenser it fits 1624 models
The diaphragm fits 8467 models
http://www.briggsand.../BRG//270026_/1
  • Bob IN said thank you
#3 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted November 12, 2013 - 09:13 PM
270026, like Don said, is a diaphragm for the Pulsa Jet carburetor, pull choke on the end of the long carburetor body.  3-5 horsepower.  They run leaf blowers, log splitters, etc.
298060 is a condenser for cast iron models with points and condensers in a box on the side of the block under the carburetor.  Big horsepower engines, 8HP and up usually, Model 19, Model 23.  Used on Simplicity tractors, Gilson, Montgomery Wards, Panzer, anything like that using the big Briggs single cylinder models.  It does need points, no electronic ignition here!
Ben W.
