Just Bought a Bush Hog T-63
78 replies to this topic
#46 olcowhand ONLINE
  • 40,341 Thanks
  • 31,169 posts
Posted December 29, 2010 - 06:01 PM
Then most likely my tractor is an early 1965 model, possibly a later 1964. Thanks Brian!
#47 Bolens 1000 ONLINE
  • 14,900 Thanks
  • 18,099 posts
Posted December 29, 2010 - 06:08 PM
I don't know what Bush hog did with their engines, but I do know in the majority of Bolens I have researched the wisconsin engines that were used were dated 1 year earlier than when the actual model came out
#48 caseguy OFFLINE
  • 1,627 Thanks
Posted December 29, 2010 - 06:27 PM
Late comer again. Thanks for the pictures Dan! That does look like it was a nice trip! Great find on the Hog too! We have a diner locally that is just like that one. The scenery around that one is MUCH nicer though!
#49 olcowhand ONLINE
  • 40,341 Thanks
  • 31,169 posts
Posted December 30, 2010 - 06:56 PM
I had hope to get her running so I could drive it off, then into the shop. I did get it started, but the float needle wasn't shutting off the fuel, so she flooded badly. Before I put fuel in the tank, she would run fine with little spurts of carb cleaner sprayed into the intake. Ran nice on carb spray & NO smoke! So I rolled it off, then pushed it to the shop. I have learned that the clutch isn't stuck, and the brakes even work great. I now have the carb off & apart, soaking in a gallon can of Berryman carb cleaner. The bowl gasket is hard as a brick, so I cut a new one from gasket material. Other than some hardened gunk inside the carb, and some in the jets, the carb is in super shape. I got the jets & passages opened easily & could have put it back together tonight, but opted for a good soaking to get it really clean. It never pays to rush things.
The throttle & choke cables were almost locked, but still moved just a bit. So they came off too for a good loosening up. They're ready to put back on. I will have it driving over the weekend. Before it flooded out, I did get to drive it a whole 3 or 4' !!
I think the engine is a winner, as well as the drivetrain, but I'll be sure once she's under full power. This purchase was a good one!
#50 Bolens 1000 ONLINE
  • 14,900 Thanks
  • 18,099 posts
Posted December 30, 2010 - 07:11 PM
Thats great to hear Daniel!
Those wisconsins are like the energizer bunny LOL They keep going and going
#51 olcowhand ONLINE
  • 40,341 Thanks
  • 31,169 posts
Posted December 30, 2010 - 07:13 PM
When I took the intake off, it looked like new in & around the intake valve area....clean as a whistle.
#52 Bolens 1000 ONLINE
  • 14,900 Thanks
  • 18,099 posts
Posted December 30, 2010 - 07:37 PM
Yep that's how my TRA-10D looked after sitting for who knows how long
(The one I bought at the flea market)
These engines amaze me
#53 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1,805 posts
Posted December 31, 2010 - 06:49 AM
Sounds like things are going to clean up nicely for you on the powerplant end!! That is always a good thing,
Tough to kill a Wisconsin short of running with low/no oil.
P.
#54 olcowhand ONLINE
  • 40,341 Thanks
  • 31,169 posts
Posted December 31, 2010 - 03:27 PM
Took her for a drive today. I think I have the carb fuel level too low though, so carb will come apart once more. Transmission, steering, & all work great too. Have an issue with the voltage regulator. If I manually contact the points inside it, it charges fine, so it's not the Delco start/gen.
#55 mjodrey OFFLINE
Posted December 31, 2010 - 03:48 PM
That sounds pretty good on the video.
#56 olcowhand ONLINE
  • 40,341 Thanks
  • 31,169 posts
Posted December 31, 2010 - 04:05 PM
Yes, but has to have a touch of choke. I think raising the float level will take care of it.
#57 caseguy OFFLINE
  • 1,627 Thanks
Posted December 31, 2010 - 04:21 PM
That sounds really good Dan! You got a great deal on this one! I'm sure that you'll get the carb issues straightened out soon enough.
#58 Bolens 1000 ONLINE
  • 14,900 Thanks
  • 18,099 posts
Posted December 31, 2010 - 04:32 PM
That S7-D sounds nice :bounce:
#59 nra1ifer OFFLINE
nra1ifer
  • 674 Thanks
  • 1,531 posts
Posted December 31, 2010 - 06:05 PM
Sounds good!
#60 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted December 31, 2010 - 10:16 PM
Thats sounds great! Is that a beel housing connected to the engine? do these have an auto style clutch?
