I Woke Up This Morning Not Expecting To Buy This Case
67 replies to this topic
#31 chris m OFFLINE
chris m
  • 3,287 Thanks
  • 4,038 posts
Posted December 01, 2013 - 02:52 PM
So Peter, Did Chris pick up that JB yet? We are waiting on pictures of him loading it up. :thumbs:
Pete is still undecided if he is going to sell it or not. But... I took a Wisconsin TRA 10D as hostage while I was there Yesterday! He thinks I am just talking it to fix it for him. :dancingbanana: :rolling:
JK Pete, I wouldn't do that to ya :D :watch_over_fence: :biting_nails: I must be careful he'll sick the dogs on me! And I'll drown from them licking me!! :rolling: :bigrofl:
  • Titus said thank you
#32 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,785 Thanks
  • 2,295 posts
Posted December 22, 2013 - 08:56 PM
Figured Id update, I gutted it & rewired it. Got her to run & she runs great!
Steering wheel is cracked and came off. I need to replace it, but the nut on the steering shaft is rusted solid. I have the torch & hope heat will help remove it.
That's all for now.
  • KennyP, gopher and Moosetales have said thanks
#33 KennyP ONLINE
  • 31,306 Thanks
  • 41,533 posts
Posted December 23, 2013 - 06:36 AM
Glad it's running!
#34 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,785 Thanks
  • 2,295 posts
Posted April 26, 2014 - 08:00 PM
Update:
The steering wheel I was able to free with a torch. The nut finally came off last weekend and today my friend Jon JB welded the steering wheel together for me. It works and I'm overall happy with the repair Vs buying a $90 steering wheel.
I got my wiring all tightened up and took her for a spin. Well sort of.
As you get to know me, you'll see that in almost every GT or item for that matter that I own, something is wrong in some way shape or form.
After priming the fuel line from sitting for so long, I got her running, when I put her in low gear, she took off in reverse.
Thankfully I planned for my misfortune and moved my F150 so I had a clear path to ride out of the garage. As I continued to ride the Case in reverse, everything felt fine except the F&R shifter. No matter what I did, I would continue to go in R.
When I came to a flat spot of land, I was able to take it out of Low, and she would idle fine. But still no Forward.
I was able to back her back into the garage and examine the linkage on the valve under the tractor. The valve on the drivers side isn't moving at all in or out. It seems to be stuck in one position, leading me to believe that it's in Reverse position currently.
Now, what can be done to correct this?
#35 chris m OFFLINE
chris m
  • 3,287 Thanks
  • 4,038 posts
Posted April 26, 2014 - 08:11 PM
Well...congrats on getting the wheel and nut off! not sure about the Case trans? On the JBII I removed the rod going to the valve, soaked it with PB Blaster then was able to work it back and forth till it was free.
Before I forget I have the piece you need for the choke cable on the BIG Case (446?)
I would come up tomorrow but I promised my dad I would help him tomorrow.
#36 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,785 Thanks
  • 2,295 posts
Posted April 26, 2014 - 08:17 PM
Chris,
    I'm heading up to northern CT tomorrow and going to try to do yard work if the weather works in my favor. I completely understand.
If you get done early and want to come by, you're more than welcome too!
I hit it with PB blaster but oddly enough, if I look close enough, it looks like it's moving slightly, but something is holding it back.
And thank you for that piece for my 444.
  • chris m said thank you
#37 gopher OFFLINE
gopher
  • 612 Thanks
  • 671 posts
Posted April 26, 2014 - 08:19 PM
Update:
pop the inspection cover off steering tower look and see if shift rod came out of controller eye.
#38 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,088 Thanks
  • 1,284 posts
Posted April 26, 2014 - 08:21 PM
Hey Titus....I'm in New Bedford, MA for the weekend and wish I could come and see your progress on the Case.
Matthew
#39 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,785 Thanks
  • 2,295 posts
Posted April 26, 2014 - 08:23 PM
You're right up the road, come over tomorrow Matt! I'll send you my number!
I did check that rod with the spring, it's in the slot, but flops around when I try to put it in F or R. It doesn't move with ease like it does on my 444.
#40 Moosetales OFFLINE
Moosetales
  • 1,088 Thanks
  • 1,284 posts
Posted April 26, 2014 - 08:26 PM
Send me a PM and we'll see if I can swing it. Hers to hoping I can make it work.
Matthew
#41 gopher OFFLINE
gopher
  • 612 Thanks
  • 671 posts
Posted April 26, 2014 - 08:45 PM
Sound like TCV spool is seized you can take end cap off and give a look see may give idea whats going on if all rusted up you could try pb blast to soak for while. tapping loose dry could damage spool and lining. Thing is if stuck in rev your lever should be in rev if not your linkage is likely bent.
#42 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,785 Thanks
  • 2,295 posts
Posted April 26, 2014 - 08:58 PM
Gopher, where is the end cap on the TCV?
#43 chris m OFFLINE
chris m
  • 3,287 Thanks
  • 4,038 posts
Posted April 26, 2014 - 09:02 PM
On the end??? :hitting_self_roller: :watch_over_fence: :poke: :D :rolling:
#44 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,785 Thanks
  • 2,295 posts
Posted April 26, 2014 - 09:09 PM
You know.....
#45 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,785 Thanks
  • 2,295 posts
Posted April 26, 2014 - 09:27 PM
Just for that, next time you're over...I'll have you show me exactly where it is.
