Vote for Tractor of the Month
I Hope I Got A Good Deal
19 replies to this topic
#16 MH81 ONLINE
  • 28,033 Thanks
  • 28,966 posts
Posted November 14, 2013 - 11:59 AM
It has the solid plastic floats. I held the pivot pin down while cranking it to see the floats in action. It starts and runs fine now so I think it just had a piece of crud in the needle seat.
Mike
If it does it again, be aware this may be an issue.
#17 UncleWillie OFFLINE
  • 13,033 Thanks
  • 7,792 posts
Posted November 14, 2013 - 12:09 PM
The pump on the Hemorrhoid got bad enough fuel was going in the block even when it was running. The replacement is sitting here on my desk.
#18 ol' stonebreaker ONLINE
ol' stonebreaker
  • 1,390 Thanks
  • 1,023 posts
Posted November 14, 2013 - 08:54 PM
  MBW, I would appreciate you telling me the make and mod# of the electric so I'll know what get for it. I found the charging problem. Another simple fix, the wire from the regulator back to ammeter turned green at the meter and broke off. Got the other wire lugs w/ it cleaned up,put a new lug on the charge wire and she charges now. Now if I can find some good used leads it'll be ready to go. I will have to order an idle solenoid. I hooked 12v directly to it and it draws juice but not enough to pull the plunger. If you push the plunger in it will barely hold in. For what I have in it I'm real happy!!
                                               Mike
#19 OldBuzzard OFFLINE
OldBuzzard
  • 6,578 Thanks
  • 4,652 posts
Posted November 15, 2013 - 05:25 AM
Just tossing this up against the wall,  but I know that back in the day, my Yamaha XS11 and a lot of other motorcycles, had a vacuum operated fuel valve on the tank.
I wonder if one of those could be made to work?
  • ol' stonebreaker said thank you
#20 ol' stonebreaker ONLINE
ol' stonebreaker
  • 1,390 Thanks
  • 1,023 posts
Posted November 15, 2013 - 10:32 AM
  Thanks, OLdBuzzard. If I have problems w/ it I'll convert to electric.
                                               Mike
