Compressor Advice/questions/disaster
16 replies to this topic
#1 chevyaddict83 OFFLINE
chevyaddict83
  • 24 Thanks
  • 68 posts
Posted November 11, 2013 - 05:29 PM
I got a nice Rol-air wheelbarrow compressor. It has*ballpark* 9 gallon tank. 5.5hp Kawasaki gas motor. Now, my dilemma. One of the tanks has a leak. Can I step up to a 40 gallon tank without doing any damage?
Sent from my SPH-L710 using Tapatalk
#2 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted November 11, 2013 - 05:32 PM
  I don't see why not. Unless the leak is a crack caused by engine vibration your well ahead to get rid of them.
                                                    Mike
#3 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted November 11, 2013 - 05:39 PM
It won't hurt the compressor to fill a bigger tank, it will just take longer, provided the compressor can handle the extra run time without getting too hot
  • MH81 and TomLGT195 have said thanks
#4 TomLGT195 OFFLINE
TomLGT195
  • 4,055 Thanks
  • 2,903 posts
Posted November 11, 2013 - 06:17 PM
I agree
Tom
#5 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted November 11, 2013 - 08:46 PM
Like Chopperhead said, know your compressor.  You need to know the CFM, and duty cycle.  If you know that, you can figure pretty quick what your compressor can handle.
Ben W.
#6 chevyaddict83 OFFLINE
chevyaddict83
  • 24 Thanks
  • 68 posts
Posted November 11, 2013 - 08:59 PM
Ben W.
Right around 9 cfm delivered, 13 displaced. No listing for duty cycle. Any clues off of that
#7 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted November 11, 2013 - 09:12 PM
AFAIK, gas powered compressors are capable of 100% duty cycle.
  • superaben said thank you
#8 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted November 11, 2013 - 09:59 PM
You might be right.  What about the air compressor itself?  Doesn't it need a cool down period too?  Maybe I'm thinking only of the el'cheapo versions.
Ben W.
#9 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted November 11, 2013 - 10:36 PM
Most compressors are air cooled. If it has the proper sheave with the fan blades, it will cool itself as long as the engine turns. I have seen a big 40 hp electric compressor with liquid cooling, but it was built in the 50s.
If it's one of the cheapo Chinese units they sell now days, they get hot quick.
#10 gopher OFFLINE
gopher
  • 768 Thanks
  • 760 posts
Posted November 11, 2013 - 11:07 PM
Like Chopperhed said no cycle for gas motor the compressors have built in bypass to keep from over pressurizing tank. Duty cycle is where resistance is keep to point of not breaking down the electrical components.
#11 chevyaddict83 OFFLINE
chevyaddict83
  • 24 Thanks
  • 68 posts
Posted November 12, 2013 - 05:33 AM
So all of this means, "yes Dave, you can use a 40 gallon tank" ?
#12 KennyP ONLINE
  • 40,984 Thanks
  • 47,152 posts
Posted November 12, 2013 - 05:40 AM
Yes Dave, you can use a 40 gallon tank! I have a gas compressor hooked to my 60 gallon tank!
#13 chevyaddict83 OFFLINE
chevyaddict83
  • 24 Thanks
  • 68 posts
Posted November 12, 2013 - 07:19 AM
Thanks guys! I've always wanted a portable. But a stationary works too.
#14 MH81 OFFLINE
  • 29,979 Thanks
Posted November 12, 2013 - 07:20 AM
The compressor should have a rating tag. It will tell you the duty cycle of the motor and compressor.
If its continuous duty, yep, no issues... If less than that, do a little research to make sure you're not going to overheat the compressor during pump up.
#15 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted November 14, 2013 - 10:33 PM
If you can find a tank you should be able to use it. I had a good compressor and the tank rotted out. There eas a shop in town that rebuilt compressors including industrial units. I went to them and bought the new reed valves and asked about buying a new tank.
They refused to sell me a tank stating lability as the reason.. I went home and patched the tank using screen wire and JB weld.
It held for about a year till my father-in-law cranked the pressure up to 120 lbs and blew the patch off.
Ifixed it again using the wire and Bondo and it held fine.
