Is anyone using a smaller resolution then 1024 x 768?
28 replies to this topic
#1 NUTNDUN OFFLINE
  • 10,353 Thanks
Posted December 15, 2010 - 09:23 PM
I need as much input from the members as possible on this. I am thinking about making the site a fixed width which means it will be 980px wide at all times. If you use a resolution of 1024 x 768 this basically wouldn't affect you. The ones it would affect will be those using larger resolutions because the site won't be full screen width.
Main reason for doing it is because it makes it easier to organize articles and picture layouts. It also makes it easier to read text, because when the text lines are real long it makes it hard for the eyes to follow to the next line.
Currently the site does not go below a width of 1000px on account of fitting the navigation menu without blurring it. So if you are running a resolution of say 800 x 600 you will have horizontal scroll.
#2 MH81 OFFLINE
  • 29,979 Thanks
Posted December 15, 2010 - 09:32 PM
If anyone doesn't know what their screen resolution is, the short answer is: Look at the bottom of your screen. If you have a scroll bar with very little adjustment, (1/4" or so) you're probably running @ 1024x768. If you have 1-2 inches in your scroll bar, you're probably using 800x600.
Another way to check is to goto Start, Control Panel, Display, Settings. It will tell you what it's set to.
I'm running 1024x768.
#3 bhts OFFLINE
bhts
  • 1,483 Thanks
  • 2,170 posts
Posted December 15, 2010 - 09:36 PM
I'm running 1366x768
#4 DH1 ONLINE
DH1
    Electric Tractors
  • 5,467 Thanks
  • 5,625 posts
Posted December 15, 2010 - 09:38 PM
I just tried mine like you say and I'm running the same as you 1024x768, can that be changed or is it fixed? On mine it looks like it's adjustable.
#5 massey driver ONLINE
massey driver
  • 1,525 Thanks
  • 1,603 posts
Posted December 15, 2010 - 09:45 PM
Just checked mine and using 1024x768 Larry
#6 olcowhand ONLINE
  • 43,135 Thanks
  • 32,005 posts
Posted December 15, 2010 - 09:58 PM
I'm set at 1680 x 1050
#7 MH81 OFFLINE
  • 29,979 Thanks
Posted December 15, 2010 - 10:49 PM
They're adjustable. The bigger the numbers, the smaller the print tho. I'm 40 now & I have to start considering things like this. :D
#8 Bolens 1000 ONLINE
  • 15,549 Thanks
  • 18,317 posts
Posted December 16, 2010 - 06:20 AM
1280 x 960
#9 mjodrey OFFLINE
Posted December 16, 2010 - 06:34 AM
I have no idea what a scroll bar is.
#10 NUTNDUN OFFLINE
  • 10,353 Thanks
Posted December 16, 2010 - 06:35 AM
I don't want you guys to have to make the resolution larger to keep it from having a scroll bar. That is why I started this thread to see what most are running at and possibly what I need to adjust so it doesn't have the side scroll. I figured it was close on the 1024 but wasn't completely sure.
#11 NUTNDUN OFFLINE
  • 10,353 Thanks
Posted December 16, 2010 - 06:36 AM
The scroll bar is the slider on the ride side of the screen to move the page up and down and depending on the fit of a page in the window for the width you will have a horizontal slider as well.
#12 tractormike OFFLINE
tractormike
  • 172 Thanks
  • 1,488 posts
Posted December 16, 2010 - 07:10 AM
Mine is set at 1366x768. No horizontal scroll bar.
#13 nra1ifer OFFLINE
nra1ifer
  • 674 Thanks
  • 1,531 posts
Posted December 16, 2010 - 07:18 AM
1280 x 800 here, full screen, no border, no horiz scroll bar
#14 mjodrey OFFLINE
Posted December 16, 2010 - 07:25 AM
OK,my scroll bar is about 1/4" wide,so does that mean I'm running 1024 x 768 ?
#15 nra1ifer OFFLINE
nra1ifer
  • 674 Thanks
  • 1,531 posts
Posted December 16, 2010 - 07:33 AM
If you are running Windows operating system, do this: "Another way to check is to goto Start, Control Panel, Display, Settings. It will tell you what it's set to."
Or, from your desktop (the screen you're at when you first boot up your PC), do a single right button mouse click on the background, select "Properties", then select the "Settings" tab. That will also get you where you need to be.
