Ff20 And A Sears Snow Blade
sears ff20 sears snow blade 917.254020 blade 917.25410
46 replies to this topic
#31 TAHOE OFFLINE
TAHOE
  • 7,814 Thanks
  • 5,612 posts
Posted November 17, 2013 - 01:11 PM
Now, if you only had something to push... :rolling:
Wash your mouth out with soap :D
I am all about being prepared, but if it doesn't happen, the happier I will be! :rocker2:
#32 KennyP ONLINE
  • 37,505 Thanks
  • 45,509 posts
Posted November 17, 2013 - 02:50 PM
Same here!
I did shove a little gravel around. Haven't checked depth yet, but it did fine with the little gravel I played in.
Aaron's Dad  peeled some persimmon seeds. Got a spoon in all 3. That supposed to mean we'll be shoveling snow this year.
  • sacsr and TomLGT195 have said thanks
#33 UncleWillie OFFLINE
  • 15,528 Thanks
  • 8,706 posts
Posted November 17, 2013 - 06:48 PM
it is almost ready fro me to come get it.
#34 KennyP ONLINE
  • 37,505 Thanks
  • 45,509 posts
Posted November 18, 2013 - 05:03 PM
I spent today getting the 'controls' made up for the blade swivel. No pics as yet. I didn't come up with any 3/8" rod, so I'll be using rebar. May be a bit before I get back to this.
  • MH81 and TomLGT195 have said thanks
#35 KennyP ONLINE
  • 37,505 Thanks
  • 45,509 posts
Posted November 27, 2013 - 04:11 PM
Update! Got the actuator rods finished up today. Weather was decent enough for me to work on these. But first, I did a little remodeling on the Tractor Port.
I now have space to bring a tractor in out of the wind! WooHoo! :dancingbanana: :dancingbanana:
Here's what I did for the rods and handles:
The bottom one is pretty neat. Lets me use my foot to release the pin for setting the angle.
  • sacsr, boyscout862 and TomLGT195 have said thanks
#36 TAHOE OFFLINE
TAHOE
  • 7,814 Thanks
  • 5,612 posts
Posted November 27, 2013 - 07:09 PM
Railroad spike and rebar....I like it!!!
#37 MH81 OFFLINE
Posted November 28, 2013 - 12:42 AM
Kenny, those look fantastic! I'm always impressed with your repurposing skills.
Couple of things; these plows move back and forth pretty easy without a load on them, but resist the temptation to try to adjust on the fly for fear of tweaking the adjuster. And where your adjuster goes thru the bar on the plow, weld a washer on the rod to keep it from sliding down and binding.
  • KennyP, sacsr, boyscout862 and 1 other said thanks
#38 KennyP ONLINE
  • 37,505 Thanks
  • 45,509 posts
Posted November 28, 2013 - 07:17 AM
Thanks guys. Look closer at the rod 'holders'. Those are 1/2" chain links cut off and 3/8" bolts welded in. I'm into cheap!
Alan, I plan to add washers on the back side where the rods hook in, just got too cool yesterday to drill the holes for cotter pins there. I don't want to weld washers there as then I can't take it all apart. Still have some paint to squirt, but it's gotta warm up some for that. I think I am going to put the lock pin rod on the outside of the upright, the RR spike is a bit close to where the side panels go. Need to source a pair of those soon.
Also, if I angle it as far as it will go, I am just even with the tire sidewalls.I may have to add some width to the blade. But this will do in a pinch. Not usually enough snow around here to push anyway! Now I need to get the blade up here for the other tractor & put it on. If I'm ready, maybe big snow will miss us.
Of note also, the Tractor Port was 40* under there when I went out & put the floor in. So my wall & door are helping.
#39 shorty ONLINE
shorty
  • 5,287 Thanks
  • 5,169 posts
Posted November 28, 2013 - 08:13 AM
Looks good Kenny. I always like it when I can reuse the materials. When I have to buy new, the project goes on hold kind of easily.
#40 ernestbbro OFFLINE
ernestbbro
  • 4 Thanks
  • 3 posts
Posted November 30, 2013 - 06:41 AM
It is neat to see how things were done years ago. None of the plowing with the storm like now a days.
#41 IamSherwood OFFLINE
  • 8,390 Thanks
Posted November 30, 2013 - 07:08 AM
Nice plow setup you've made yourself there Kenny.
I hope you get lots of snow to play with it in.
You know Kenny, those RR spikes make great coat hooks too.
I put them in the E-tank, then cut the point off, weld it to a piece
of 1/4 x 1 x 2 1/2 flat bar with 2 holes drilled in it. Clean up the weld
a bit and spray with lacquer. If you know anyone that has a room in
their house that has a RR motif, they'd love a couple.
Oh, can you tell more about this?
"Aaron's Dad  peeled some persimmon seeds. Got a spoon in all 3."
#42 KennyP ONLINE
  • 37,505 Thanks
  • 45,509 posts
Posted November 30, 2013 - 07:17 AM
Here's something on the persimmon seeds.
This spike was dug up as I was moving gravel about. I picked it up and put it on the bench. When I went to find something to use for a 'pedal', it just looked like the best thing. I need to add a bit more weight on the back, as I don't have chains for either of the FF's.
  • IamSherwood, Cat385B and boyscout862 have said thanks
#43 Cat385B ONLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted November 30, 2013 - 07:19 AM
Winter weather predicting using fruit. Cut open 3 persimmons and see what shape the seed kernel inside resembles. Spoon shape means lots of snow, fork means mild winter. There is something else, too. Can't remember..yahoo doesn't know.
EDIT: Kenny got it! Knife shape means windy and cold...
  • IamSherwood, KennyP and boyscout862 have said thanks
#44 IamSherwood OFFLINE
  • 8,390 Thanks
Posted November 30, 2013 - 07:52 AM
Never heard of that. Thanks.
I predict the winter based on how much firewood the old guy down the road has stacked.
#45 KennyP ONLINE
  • 37,505 Thanks
  • 45,509 posts
Posted November 30, 2013 - 08:14 AM
Now you know why I am putting blades on tractors, Will! Gotta be prepared!
  • IamSherwood and boyscout862 have said thanks
Also tagged with one or more of these keywords: sears ff20, sears snow blade, 917.254020 blade, 917.25410
