Gutter Cleaner That Works
15 replies to this topic
#1 oldtimer OFFLINE
oldtimer
  • 374 Thanks
  • 339 posts
Posted November 09, 2013 - 07:47 AM
    I needed to  clean the roof gutters on our house and I had ordered a kit for my leaf blower when I boght it. Turned out that it was too much of a chore for this out of shape old geezer to hold the leaf blower up for any length of time, so my grandson used to do it for me.  He's been in the Marines for the past couple of years and so the gutters haven't been cleaned.  I looked at stuff for sale on the internet and  saw a few shop vac kits that seemed like they'd work, so I took a chance and bought the kit for my Ridgid shop vac from Home Depot.  The general use seemed to be to vacuum, but that would mean bringing it down and unclogging the tube every few minutes.  Sure, that'd work but would take a lonnng time.
     I decided to get some large hose ( pvc ? )  clamps and tighten the wands/ tubes together and attach it to the exhaust port of the shop vac.  I bought two extra wands at HD, too, so that I could have easier control.  I am happy to report that this set up works like a charm !!  I only did about half of the back gutter because we had company show up, but it was  much easier than wielding a leaf blower. I'll go out later on today  and finish the job.
    Just thought I'd pass this on to anyone who's interested in a light and easy way  to clean their gutters.  higher roof?  ------  more wands.
  • MH81, hamman, IamSherwood and 7 others have said thanks
#2 KennyP ONLINE
  • 40,198 Thanks
  • 46,801 posts
Posted November 09, 2013 - 07:57 AM
Sounds like a good idea to me!
  • hamman and JRJ have said thanks
#3 IamSherwood OFFLINE
  • 8,395 Thanks
Posted November 09, 2013 - 08:05 AM
Good idea. Glad it worked for you. Thanks for reminding me.
I gotta chase the wife up the ladder soon. :smilewink:
#4 KC9KAS ONLINE
KC9KAS
  • 5,445 Thanks
  • 4,712 posts
Posted November 09, 2013 - 08:53 AM
You should have let the company help finish the job! :bigrofl:
Thanks for the idea!
#5 TomLGT195 OFFLINE
TomLGT195
  • 4,017 Thanks
  • 2,884 posts
Posted November 09, 2013 - 09:18 AM
thanks for the reminder, got to do mine too.
Tom
#6 Sawdust OFFLINE
Sawdust
  • 6,047 Thanks
  • 3,502 posts
Posted November 09, 2013 - 09:19 AM
Didn't you have to elbow the end so it would blow onto the gutter?
#7 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted November 09, 2013 - 09:41 AM
Ha you OT, how about a picture of your set up so we can understand exactly what you used.
Dick
  • hamman said thank you
#8 shorty ONLINE
shorty
  • 5,774 Thanks
  • 5,391 posts
Posted November 09, 2013 - 10:08 AM
So far I haven't had to clean the gutters. Maybe the winds that we have does it for me.  :D  I still go up and check every so often.
#9 oldtimer OFFLINE
oldtimer
  • 374 Thanks
  • 339 posts
Posted November 09, 2013 - 10:51 AM
JRJ, I'll try to post a picture later on.  Here's the kit from HD  All you need is the clamps and as many wands as you may need.  ..........  http://www.homedepot...d_At_Home_Depot
  • Sawdust said thank you
#10 hamman ONLINE
hamman
    Homelite Owner Extraordinaire
  • 6,580 Thanks
  • 2,906 posts
Posted November 09, 2013 - 11:46 AM
NIce idea. I used a piece of 3/4" and 1/2" coppeer pipe. Attached it to my aircompressor. I flattened out the end of the 1/2" to make it wider and narrower. Fitted up the pipe using copper elbows and 45+ angles. I also attached a handle using a 3/4" tee about a foot up from the fittings where it attaches to the air hose. I put in a 3/4" ball vale to regulate the air. It worked great. I don't have a picture as I made this about 35yrs ago for my dad. It was about 10' long and wasn't that heavy. Dad was 65 then and he handled it very well. Thanks. for reminding me. Roger.
#11 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted November 09, 2013 - 07:45 PM
Sounds like it is working out well for you. I have a lot of pine trees and the needles are hard to keep out of the gutters. I just did mine the other day and had to use a ladder and dig the needles out with my bare hands because they were packed in really tight. It would be much easier to do it from the ground.
#12 dodge trucker ONLINE
dodge trucker
  • 2,697 Thanks
  • 3,351 posts
Posted November 11, 2013 - 07:27 PM
did mine the old way today on both the house and garage,  set up ladder, scoop with hand as far as I could reach both directions, climb down, move ladder, repeat as wet as the ones at the bottom were there was no way a shop vac or yard blower would have gotten them outta there
#13 dodge trucker ONLINE
dodge trucker
  • 2,697 Thanks
  • 3,351 posts
Posted November 11, 2013 - 07:28 PM
other than the not being able to see if you got everything while standing on the ground
  • JDBrian said thank you
#14 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted November 12, 2013 - 07:54 AM
True. I'm thinking of replacing all my longer standard gutters with the larger size. The roof is large and they overflow often in heavy rain. I also have some leaks at the corners that have defied my attempts to fix them. It may be easier to just hire an expert to come in and replace the works. They are 20 yrs old.
#15 oldtimer OFFLINE
oldtimer
  • 374 Thanks
  • 339 posts
Posted November 20, 2013 - 03:09 PM
Not a problem.  You can feel the bottom of the gutter.   Two years of junk took longer than I expected. That, and me only being able to do a little at a time due to my C.O.PD.   I found my camera today.  I'll try to post a pic on the next sunny day.
