I Found This At The Scrap Yard Today.
18 replies to this topic
#1 scuffy727 OFFLINE
scuffy727
  • 131 Thanks
  • 92 posts
Posted November 08, 2013 - 08:58 PM
I found this at the scrap yard today.  A two cylinder Wisconsin and it is not locked up and has fire on both cylinders.  Going to try starting it tomorrow.
  • MH81, Alc, KennyP and 7 others have said thanks
#2 wvbuzzmaster OFFLINE
  • 4,662 Thanks
  • 7,407 posts
Posted November 08, 2013 - 09:01 PM
Nice score. Remember to check the oil first.
  • JRJ said thank you
#3 scuffy727 OFFLINE
scuffy727
  • 131 Thanks
  • 92 posts
Posted November 08, 2013 - 09:08 PM
I've already checked and it will definitely need some since it was on its side leaking allover the place.
#4 MH81 ONLINE
  • 28,856 Thanks
  • 29,259 posts
Posted November 08, 2013 - 09:13 PM
Really nice power plant there. Hope it starts up for you.
#5 KC9KAS OFFLINE
KC9KAS
  • 5,057 Thanks
  • 4,461 posts
Posted November 08, 2013 - 09:14 PM
Great save!
#6 scuffy727 OFFLINE
scuffy727
  • 131 Thanks
  • 92 posts
Posted November 08, 2013 - 09:22 PM
Best of all the guy that runs the scrap yard only charged me $20.
  • sacsr, boyscout862 and JRJ have said thanks
#7 Gtractor OFFLINE
Gtractor
    The Tractor Hoarder
  • 7,717 Thanks
  • 4,314 posts
Posted November 08, 2013 - 09:33 PM
PLEASE, PLEASE, PLEASE,  do yourself a favor and unhook one end of the metal oil line that runs to the governor assembly and turn the engine over to make sure it is pumping oil.  If it pukes oil it will be OK to proceed with starting.   If no oil comes out of that line DO NOT try to start it until you have it pumping.  More than likely it will oil but you need to know before starting.
If the model if "TF", "TFD", "TH", or "THD" it will fire both plugs at the same time - one spark is wasted in the exhaust of the other cylinders stroke.  On those models listed the pistons move up and down at the same time.  There is a huge counterwieght on the crankshaft to smooth things out.
If it a model "TJ" or "TJD"  the pistons move opposite directions and will only spark one plug at a time.
Those are great engines - heavy as all heck but good and powerful.
Best of Luck!!!
  • Alc, motobreeder, Titus and 5 others have said thanks
#8 Titus ONLINE
Titus
    Bush Hog Hoarder
  • 1,786 Thanks
  • 2,297 posts
Posted November 09, 2013 - 12:02 AM
$20? You stole it! Local scrap yard here would try to sell that for $100+ I bet
#9 JDBrian OFFLINE
  • 9,594 Thanks
Posted November 09, 2013 - 07:34 AM
Very nice find. Do you have an application in mind for it?
#10 LilysDad ONLINE
LilysDad
    --Crazy about GTTalk-- 'sort of'
  • 10,952 Thanks
  • 8,381 posts
Posted November 09, 2013 - 07:43 AM
I have a larger gas tank for that if you want it.
#11 superaben OFFLINE
superaben
    Con Man
  • 7,665 Thanks
  • 5,677 posts
Posted November 09, 2013 - 08:10 AM
Very nice save for a very, very nice price.  I tore up an old Wisconsin TFD a few months ago that was stuck solid, spoiled my wish to hear one run.
Ben W.
#12 boyscout862 ONLINE
  • 10,775 Thanks
  • 8,075 posts
Posted November 09, 2013 - 08:23 AM
They are great engines. I have a couple of them on generators. After the oil pump test, I would change the oil and turn it over a dozen times before trying to start it. Good Luck, Rick
#13 scuffy727 OFFLINE
scuffy727
  • 131 Thanks
  • 92 posts
Posted November 09, 2013 - 01:13 PM
After doing the oil pump test and cleaning the carb. it started right up.  The gear reduction on the rear of the engine was bad, but the engine runs better since I took it off.  The gear reduction had a bad bearing in it and I guess that is why they got rid of it.  I really don't have any plans for it at this time, I was interested in it because it was so big and when he told me the price I had to have it.
  • olcowhand, Gtractor and MFDAC have said thanks
#14 MFDAC ONLINE
MFDAC
  • 2,554 Thanks
  • 1,317 posts
Posted November 09, 2013 - 07:32 PM
I have a Wisconsin TF that was given to me a while back that I have to try to start one of these days, Glad yours fired right up! I'm envyous that you have electric start!
Later---DAC
#15 MadAtGrass OFFLINE
MadAtGrass
  • 76 Thanks
  • 46 posts
Posted November 09, 2013 - 10:09 PM
I did a quick search of Craig's List in my area (and beyond) and something close is up for sale for $150, motor only. It came off of a New Holland Baler. You can check it out for yourself though. http://nh.craigslist...4121918492.html
I would have grabbed it for $20.00 as well. Forget having a use for it.
  • MFDAC said thank you
