John Deere 420 hydrostatic fluid check
6 replies to this topic
#1 Reverend Blair OFFLINE
Reverend Blair
  • 501 Thanks
  • 952 posts
Posted December 14, 2010 - 06:06 PM
How do I check the fluid level for hydraulics/hydrostatic drive on a John Deere 420? I've been told there should be some sort of sight on the back of the tractor or under the seat, and if you can see fluid in it it has enough, but I don't see anything there.
There is a piece of what might have been clear tubing at one time, but it's not clear anymore. Is that the level sight? It looks more like a fuel line.
#2 olcowhand ONLINE
  • 38,811 Thanks
  • 30,703 posts
Posted December 14, 2010 - 06:22 PM
Yep, that tube is the sight level for the oil. You just need to replace with new line. I believe there is a metal clip part way up the rear that the oil level should stay between the ends of.
  • Reverend Blair said thank you
#3 grnspot110 ONLINE
grnspot110
  • 3,976 Thanks
  • 2,579 posts
Posted December 14, 2010 - 07:44 PM
Correct! The originals were glass inside the bracket ( on the rear frame to the right & above the drawbar). Replacement is just a piece of plastic tubing. Oil level should be within the bracket. ~~ grnspot110
#4 Reverend Blair OFFLINE
Reverend Blair
  • 501 Thanks
  • 952 posts
Posted December 14, 2010 - 08:08 PM
Excellent. Now when my buddy calls me back, I can say, "never mind" instead of asking him the question. Come to think of it, he was looking back there when we looked at the tractor before buying it.
#5 Alc ONLINE
  • 6,435 Thanks
  • 7,238 posts
Posted December 14, 2010 - 09:02 PM
You might want to check a owners manual to see if the engine needs to be a idle when your checking it , my 318 and 400 need to be idling.
#6 luscikauskas OFFLINE
luscikauskas
  • 2 posts
Posted April 19, 2011 - 09:47 AM
Just wanted to ask, is it OK, for the tube end to be open to the top of the check glass?
#7 olcowhand ONLINE
  • 38,811 Thanks
  • 30,703 posts
Posted April 19, 2011 - 10:19 AM
It is supposed to have a breather on the end. If it is plugged, the oil can't come up the tube to show the fluid level. You can use a tiny fuel filter, then add a short piece of tubing off the top of the filter, turning it downward to help prevent water from entering.
