B&s Engine...what Is It?
10 replies to this topic
#1 WHdbJD OFFLINE
WHdbJD
  • 671 Thanks
  • 510 posts
Posted November 07, 2013 - 08:42 PM
No tag on this engine>  I looked in my B&S book, looks like a 80200
series 3 HP.
  • JRJ said thank you
#2 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted November 07, 2013 - 09:32 PM
There's a number somewhere, unless the shroud was replaced.  Its probably painted in so you can't find it easy.  Try the side right above the gas tank.
Ben W.
  • WHdbJD said thank you
#3 bowtiebutler956 OFFLINE
bowtiebutler956
  • 660 Thanks
  • 796 posts
Posted November 07, 2013 - 11:01 PM
 As already stated, the numbers should be stamped on the shroud. However I do agree with your assessment that it appears to be a 8xxxx series 3hp engine.
Matt
#4 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted November 08, 2013 - 11:35 AM
With the centrifugal clutch it was probably from a mini bike or go cart.
#5 WHdbJD OFFLINE
WHdbJD
  • 671 Thanks
  • 510 posts
Posted November 08, 2013 - 08:18 PM
Thanks,  I'll look a little closer.  There is lots of paint on it,  some one took a spray can
to it and painted it , dirt and all!
#6 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 9,654 Thanks
  • 5,851 posts
Posted November 13, 2013 - 12:45 PM
Is that a V-belt clutch?
Looks like a Vplex belt clutch on there
#7 WHdbJD OFFLINE
WHdbJD
  • 671 Thanks
  • 510 posts
Posted November 13, 2013 - 10:18 PM
Yes, it is a V belt clutch.
#8 WHdbJD OFFLINE
WHdbJD
  • 671 Thanks
  • 510 posts
Posted December 27, 2013 - 02:25 PM
I have not found a number on it yet.  It's very lightweight, magnet wont stick to it.
Did B&S make an aluminum block engine?
#9 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted December 27, 2013 - 03:37 PM
It does look just like my 80212 Briggs I have on a lawn vacuum.  I also have one startting with 81, but it's an updraft carb, unlike these in-tank ones.
Edited by cookiemonster, December 27, 2013 - 03:37 PM.
#10 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted December 27, 2013 - 06:10 PM
Try 92500 series,
#11 adamjd200 OFFLINE
adamjd200
  • 2,031 Thanks
  • 2,156 posts
Posted December 29, 2013 - 10:01 PM
Yes they made aluminum block engines, my 6b-s is aluminum.
