Kubota D600 Hyd. Pump.
3 replies to this topic
#1 Enginerod OFFLINE
Enginerod
  • 234 Thanks
  • 289 posts
Posted November 07, 2013 - 05:08 PM
I was just wondering if anyone has seen a D600 with the hydraulic pump driven off the back of the injector pump. My 2cyl. Yanmar is like this and it seems like that would be a good place to drive it from if possible. There is a block off plate there so it looks like it was designed to have a pump there.
#2 EconChuck OFFLINE
EconChuck
  • 252 Thanks
  • 289 posts
Posted November 07, 2013 - 10:11 PM
Hi,
I'm reasonably sure there was a setup like that on ebay a couple of months ago.
I don't remember what it sold for tho.
Chuck
  • Enginerod said thank you
#3 skyrydr2 OFFLINE
  • 3,886 Thanks
  • 3,410 posts
Posted November 08, 2013 - 04:16 AM
That is very common, and can be fitted in minutes. Only issue is finding one at a reasonable price. The pump is " special" as it is designed to run at a slower speed(1/2 crank speed) and pump about 6gpm at 3000 psi.
#4 Enginerod OFFLINE
Enginerod
  • 234 Thanks
  • 289 posts
Posted November 08, 2013 - 07:54 AM
Thanks for the responses, I'll have to keep my eye out for one. I would like to add power steering and hyd lift and that would be the easiest way to run the pump.
