Case 444 J54 Snow Plow Install Instructions?
4 replies to this topic
#1 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,822 Thanks
  • 2,324 posts
Posted November 07, 2013 - 04:48 PM
Anyone have them handy or photos of how it's install correctly? Mine is under the axle. Thanks!
  • JRJ said thank you
#2 gopher OFFLINE
gopher
  • 742 Thanks
  • 746 posts
Posted November 07, 2013 - 07:52 PM
Help if I can what is it you need to know? The quick connect or the lift rod?
#3 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,822 Thanks
  • 2,324 posts
Posted November 08, 2013 - 12:07 AM
Lift rod, QD was pretty easy to figure out, it's getting the rod mounted to the right hole in that lift bracket is where I'm getting lost.
#4 gopher OFFLINE
gopher
  • 742 Thanks
  • 746 posts
Posted November 08, 2013 - 01:01 AM
See if I can tell you with adapter plate on tractor no matter what plate you have the holes are in pairs . The 200 plow hole is the one closest to edge facing rear of tractor the 400 is the hole towards front. The drawing shows the yellow is for 200 the red is for your 400series
  • Mjoe7 said thank you
#5 Mjoe7 OFFLINE
Mjoe7
  • 172 Thanks
  • 172 posts
Posted November 08, 2013 - 05:41 AM
A few pics that I hope will help. I sent this to your messages with more detail.
Posting here for others.
In this video of me you can see I have the older style of plow lift and did not have the correct lift link so I made due like how you see. It worked ok until I broke the lift cylinder mount under the tractor.
http://www.youtube.c...h?v=fPnD22i10Pk
Edited by Mjoe7, November 08, 2013 - 05:47 AM.
