For Sale
Kohler 12Hp Engine
2 replies to this topic
#1 farmerall OFFLINE
farmerall
  • 2,202 Thanks
  • 1,473 posts
Posted November 04, 2013 - 06:57 PM
Up for sale is another one of the projects I may never get around to. It is a Kohler 12hp engine that I got with a Speedex tractor I bought back in the spring. I was told that the engine had a rod knock and the PO dissembled the engine to find the problem and then put it back together. I believe him because everything is put together finger tight. I have not looked into how bad the rod is so assume it needs a complete rebuild. The engine is one of the multi use ones that has the big gas tank mounted on the side of the engine. The engine is complete with the carb, coil and everything else. I was going to rebuild this and then put it on a shelf for a spare engine. Well so far I have put it on the shelf and haven't touched it since.
I'm asking 75 obo
Located near Pittsburgh Pa
#2 Guest_Fluid_*
Guest_Fluid_*
  • Guests
Posted November 04, 2013 - 09:07 PM
I'm asking 75 obo
What is the shaft size?
#3 farmerall OFFLINE
farmerall
  • 2,202 Thanks
  • 1,473 posts
Posted November 04, 2013 - 09:28 PM
I will have to measure it.
