Bush Hog Hd-12 Diesel Repower
282 replies to this topic
#271 olcowhand ONLINE
  • 43,178 Thanks
  • 32,014 posts
Posted April 03, 2014 - 06:47 PM
So you made up a slotted arrangement, much like on a MF12
sleeve hitch?
I did the same on the MF8E I added the hydraulics to back in the fall.
Something has to give, or stuff breaks.
No, not slotted.  A hinged setup that swings away or pulls up against the OE lift bar.  Sort of how the MF1650 thru 1855 is.
  • IamSherwood said thank you
#272 olcowhand ONLINE
  • 43,178 Thanks
  • 32,014 posts
Posted April 03, 2014 - 07:04 PM
It has a slotted lift link that went to the belly lift.  I removed it to add my pivot system as it was in the way.  I'll snap a pic tomorrow.
#273 olcowhand ONLINE
  • 43,178 Thanks
  • 32,014 posts
Posted April 03, 2014 - 07:30 PM
Will, the main reason I didn't build a slotted system was due to the loooong stroke of the cylinder.  I didn't measure the stroke, but I'd say it's a good 8".  You'll understand once you see the pics.
#274 Robert Webb OFFLINE
Robert Webb
  • 930 Thanks
  • 436 posts
Posted April 05, 2014 - 08:13 AM
Daniel...............hope you have that thing ready for the Ball Hollow Plow day......................we can take a picture of the "Beauty and the Beast".................lmao
  • olcowhand said thank you
#275 olcowhand ONLINE
  • 43,178 Thanks
  • 32,014 posts
Posted April 05, 2014 - 08:31 AM
The "beast" is ready NOW!  Bring it on!  :thumbs:
#276 olcowhand ONLINE
  • 43,178 Thanks
  • 32,014 posts
Posted April 05, 2014 - 04:27 PM
Here's my float mechanism.  Sure wish they had used the same valve as on the JB series, as it had a float position.  Anyways, you can see between the 2 pics how it hinges, allowing upward movement of the lift without moving the cylinder shaft.  In the last pic, the lower end back plate hits the vertical 3pt arm to prevent bending the cylinder shaft in case of something causing the implement from coming up too high.
  • limebuzz, Alc, Texas Deere and Horse and 7 others have said thanks
#277 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,467 Thanks
  • 5,625 posts
Posted April 05, 2014 - 05:13 PM
Good idea makes the hitch floating. :thumbs:
#278 Texas Deere and Horse OFFLINE
  • 14,901 Thanks
  • 15,518 posts
Posted April 05, 2014 - 09:34 PM
Daniel, that is a great solution to the too long cylinder stroke. Very nice job !! :thumbs:
#279 olcowhand ONLINE
  • 43,178 Thanks
  • 32,014 posts
Posted April 07, 2014 - 05:20 PM
Won ebay auction for an OE KD540 fender tail light for the HD-12.  Cost me a little over $32 delivered, but these are getting harder to find, and always bring several bucks.  Should be here in a couple or 3 days.
  • Texas Deere and Horse, KennyP, sacsr and 1 other said thanks
#280 KennyP OFFLINE
  • 41,506 Thanks
  • 47,416 posts
Posted April 07, 2014 - 05:41 PM
Cool light!
#281 olcowhand ONLINE
  • 43,178 Thanks
  • 32,014 posts
Posted April 07, 2014 - 05:55 PM
I swapped the numbers when I typed.  It cost me a bit over $32, not 23.
#282 IamSherwood OFFLINE
  • 8,395 Thanks
Posted April 07, 2014 - 06:17 PM
Nice to have the OE light.
My best estimate, is that it'll take about 5 minutes after
you install it, that you'll start thinking about painting. :smilewink:
  • Cat385B said thank you
#283 Texas Deere and Horse OFFLINE
  • 14,901 Thanks
  • 15,518 posts
Posted April 07, 2014 - 06:39 PM
Glad you were able to get it bought. I was afraid it would get too high.
