Bush Hog Hd-12 Diesel Repower
282 replies to this topic
#166 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,793 Thanks
  • 1,003 posts
Posted December 01, 2013 - 12:00 PM
Looks great. My Ford 9N has the exhaust the same way, works great except in tall dry grass. Started a fire with it once! A spark arrestor would have stopped it, if I had had one.
#167 KennyP ONLINE
  • 38,242 Thanks
  • 45,869 posts
Posted December 01, 2013 - 12:23 PM
That should work! You don't have a mower deck, so it's not in the way of that.
#168 Texas Deere and Horse ONLINE
  • 14,796 Thanks
  • 15,495 posts
Posted December 01, 2013 - 01:10 PM
Running it that way will give it that "50's" feel and I think it will really look good..
#169 olcowhand ONLINE
  • 41,055 Thanks
  • 31,392 posts
Posted December 01, 2013 - 07:48 PM
 Ran & got Chinese for lunch today.  Swung by TSC & got a small Ford muffler for the HD-12.  Smaller than the oval & will tuck in nicely just under the footrests.  $27, but will last my lifetime, so not bad.  Will need to have a pipe bent for the 90 degree turn this week if I get time.
  • Texas Deere and Horse and sacsr have said thanks
#170 IamSherwood OFFLINE
  • 8,391 Thanks
Posted December 01, 2013 - 08:14 PM
That'll be nice. At least my er...your left foot will be warm next winter.
  • olcowhand said thank you
#171 olcowhand ONLINE
  • 41,055 Thanks
  • 31,392 posts
Posted December 01, 2013 - 08:20 PM
If it does get too warm, I can get some of that self stick heat shield to place under the footrest.  :thumbs:
#172 IamSherwood OFFLINE
  • 8,391 Thanks
Posted December 01, 2013 - 08:34 PM
Yep, that'll work. It'll be nice getting the exhaust away from your face too.
#173 olcowhand ONLINE
  • 41,055 Thanks
  • 31,392 posts
Posted December 05, 2013 - 12:09 PM
Once I got the shop halfway straightened up this morning, I stole a little time to work on the HD-12.  I removed the heater hose loop from the water pump and plugged one hole.  Then I found a temp sender adapter that fit the fan switch, so installed it there.  I had intended to put it in the radiator, but the threads didn't match and I didn't want to mess with the aluminum radiator & damage it.  I started it & let it run while I did more shop cleaning till she got to full temps and the fan cycled perfectly.  On at 195, off about 180.
Since deciding to go with the electric fan instead of engine driven fan, it was time to get it mounted.
I found an oil filter that was shorter to fit my remote adapter, but there's still not enough room due to the steering drag arm to just drill holes in the chassis & fit it out of sight.  So looks like I'll have to add a 2" tall piece of metal on the top edge of the frame to bolt it up to.
  • Texas Deere and Horse and KennyP have said thanks
#174 KennyP ONLINE
  • 38,242 Thanks
  • 45,869 posts
Posted December 05, 2013 - 12:36 PM
Glad you are getting some therapy. Been watching the weather, might get nasty your way before long. Be safe!
#175 olcowhand ONLINE
  • 41,055 Thanks
  • 31,392 posts
Posted December 05, 2013 - 01:01 PM
Forgot to add....the electric fan will not hardly be noticeable at all once the grill is in.
  • Texas Deere and Horse, wvbuzzmaster, Titus and 1 other said thanks
#176 Texas Deere and Horse ONLINE
  • 14,796 Thanks
  • 15,495 posts
Posted December 05, 2013 - 03:16 PM
Sure looks good Daniel. I really like how the grill hides the fan.
#177 IamSherwood OFFLINE
  • 8,391 Thanks
Posted December 05, 2013 - 06:29 PM
I'm sure it'll look Ok, adding to the frame for the filter, but I just thought I'd ask, if there is any
other place to mount it? Just in case the grey matter is a bit numb from all the other
goings on. :thumbs:
#178 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted December 05, 2013 - 08:06 PM
Any room for the filter on the inside side of the dash tower?
#179 olcowhand ONLINE
  • 41,055 Thanks
  • 31,392 posts
Posted December 05, 2013 - 08:25 PM
goings on. :thumbs:
Well, I've not really looked past where the hoses will reach.  Trying to keep this as low buck as possible, so I don't want to have to buy new hoses, but I'll check it out further.
#180 IamSherwood OFFLINE
  • 8,391 Thanks
Posted December 05, 2013 - 08:53 PM
What are those hoses? 3/8" hydraulic 1 wire with NPT?
