Gas Tank Repairable?
12 replies to this topic
  • 2,331 Thanks
  • 1,498 posts
Posted November 03, 2013 - 06:27 PM
So, I finally dragged the Waterloo model 15 into the garage as a winter project.  It has (as opposed to should have) a 2 hp Briggs engine (60102 1015 01) from the 1980s (82040703) on it.  The tank had serious rust in it and it will eventually get Red Koted.  My immediate problem is that the tank leaks at the horizontal seam around the middle.
My question is: What is the best way to fix the leak?  Solder, epoxy, JB Weld, brazing, etc....
  • boyscout862 and JRJ have said thanks
#2 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted November 03, 2013 - 06:34 PM
jb weld ought to fix that just make sure you clean it up good
  • New.Canadian.DB.Owner and JRJ have said thanks
#3 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,436 Thanks
  • 2,860 posts
Posted November 03, 2013 - 07:15 PM
Do you have a radiator repair shop close? If so they can repair it. JB Weld will also fix it. take your time to clean it and prep it for the JB. You may be able to crimp the seam if it has come un crimped.. I can't tell by the picture if it is rusted or simply leaking at the crimp. Good Luck.
#4 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted November 03, 2013 - 07:36 PM
They say the best place to take a gas tank with problems is a radiator shop and I wish you luck at getting it fixed properly.
Dick
Edited by JRJ, November 05, 2013 - 09:08 AM.
#5 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted November 03, 2013 - 07:42 PM
JB Weld is what I have used.  For big gas tanks, I second the radiator shop.
Ben W.
#6 DougT OFFLINE
DougT
    Dog Approved
  • 6,926 Thanks
  • 4,994 posts
Posted November 03, 2013 - 08:27 PM
I would clean the tank out good with maybe a light muratic acid. follow that with a good rinse and let it dry. Then use the tank sealer. I've never used redkote but the sealers I've used advertise they can stop small pinholes. I'd let the sealer permeate that seam real good with nothing holding it back on the outsid. If it leaks too fast, use some tape or matting to hold it. If you want to use JB after the fact, it will be fine but I wouldn't use it first. My experience has been if the gas can get to the backside of the JB it wil usually come loose and leak. They make a 2 part putty they claim will seal in gas but I've never had much luck with it either. I wouldn't think that tank would be real hard to find.
  • Alc, New.Canadian.DB.Owner and JRJ have said thanks
#7 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted November 03, 2013 - 09:24 PM
,,, I wouldn't think that tank would be real hard to find.
You make a good point: it costs about C$65 to get it Red Koted at my local rad shop or I could do it myself for about C$30, but  a new tank is only about C$60.  BUT, if I buy a new tank, what will I do with the old one?  It can be repaired, so I feel obligated to repair it.  If I buy a new tank, am I still going to fix the old one?  Likely.  So buying a new one actually costs me two or three times the price of fixing the old one.  Call it "new math".
  • IamSherwood said thank you
#8 Texas Deere and Horse ONLINE
  • 14,811 Thanks
  • 15,500 posts
Posted November 03, 2013 - 09:31 PM
If I were you, I would repair the tank myself. Wash it out very well to get all the gas fumes out of it and soldier it myself. If you can soldier Copper pipes together, you can fix this tank.
#9 EricFromPa ONLINE
EricFromPa
  • 3,658 Thanks
  • 3,113 posts
Posted November 04, 2013 - 12:00 AM
muratic acid works great for removing rust BUT it will need to be sealed within minutes of flushing the acid out of the tank.If you don't seal the inside of the tank after the metal is oxidised by the Muratic acid it will rust 10x worse than the tank was before you cleaned it within a couple of days.
I ruined a motorcycle tank that I was trying to clean out with acid.I thought I had a can of gas tank liner but it had dried up and by the time I had the time to go get some (almost a week) the rust had returned with a vengeance.Rust was so thick that it was literately flaking.
If you solder the seam you are going to have to solder the whole way around.The heat will melt the sealant that they use on the seem.
You could heat it and burn the sealant out of the seem and take the tank apart and clean it then Solder the seem back up then coat the tank.That way you know if there are any thin spots in the bottom and you could solder those up before you put the sealer in.
  • DougT, New.Canadian.DB.Owner and Dwight68 have said thanks
#10 Kfs35 OFFLINE
Kfs35
  • 408 Thanks
  • 416 posts
Posted November 04, 2013 - 11:34 AM
Personally, I would buy a new tank, and scrap/throw that one away.  It's not the original engine/tank for your tractor, so to me, it's not worth messing with.
#11 hamman OFFLINE
hamman
  • 6,436 Thanks
  • 2,860 posts
Posted November 04, 2013 - 10:17 PM
I've used the product KREEM on my sons Honda 4 wheeler tank. It has been coated and had JB Weld applied prior to coating. It is still holding nearly 3 years now. Just takes a lot of prep time. Roger.
#12 Big John OFFLINE
Big John
  • 24 Thanks
  • 96 posts
Posted November 05, 2013 - 11:59 AM
No matter how many times U wash it out U it still could explode. Soldering it is too risky.  Use JB Weld or some other sealer or buy
another tank.
#13 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted November 05, 2013 - 05:29 PM
I keep thinking about any gas fumes that may be lingering around any corner in the old tank, it doesn't take but one boom and you know what that means. I'm sorry it is better to be safe than sorry. If you take it to a radiator shop it is out of your hair and I think the shop will stand behind there work and if they decide to do it they should stand behind the work.
 What does you wife say.
 With all the time and thinking about this that everyone has put into it you could have ordered a new tank and be waiting for it and thinking about your next project.
Dick
