My New Cub 100!
19 replies to this topic
#1 CubHorse80 OFFLINE
CubHorse80
  • 159 Thanks
  • 318 posts
Posted November 01, 2013 - 08:18 PM
I have been wanting this for a while, and i caved in. $250 and it was mine...
Its in decent shape, and has fenders!!!! :dancingbanana:
Edited by RallyRoperGT18, November 01, 2013 - 09:03 PM.
  • boyscout862 and 68chevyguy have said thanks
#2 farmerall OFFLINE
farmerall
  • 2,207 Thanks
  • 1,475 posts
Posted November 01, 2013 - 08:50 PM
Cub Cadet 100?
  • CubHorse80 said thank you
#3 diesel nut OFFLINE
diesel nut
  • 763 Thanks
  • 457 posts
Posted November 01, 2013 - 09:02 PM
I'd say a 70 or 100 from the pic of the corner of the grill
#4 CubHorse80 OFFLINE
CubHorse80
  • 159 Thanks
  • 318 posts
Posted November 01, 2013 - 09:03 PM
DING DING DING DING!!!!! WINNER!
Yes A cub 100! with fenders!
#5 CubHorse80 OFFLINE
CubHorse80
  • 159 Thanks
  • 318 posts
Posted November 01, 2013 - 09:04 PM
Heres some more pics!
It aint bad, except for the deck...
Edited by RallyRoperGT18, November 01, 2013 - 09:06 PM.
  • farmerall said thank you
#6 CubHorse80 OFFLINE
CubHorse80
  • 159 Thanks
  • 318 posts
Posted November 01, 2013 - 09:08 PM
But i have a question...
Does the 10 and 12hp have the same block? i took the tank off, and it has a 12hp sticker on her... could it just be a different shroud? or is it a 12hp..
So, a 100 or a 120? :bigrofl: :bigrofl:
#7 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
That's how you can tell a real tractor guy, when he can identify a model by just a piece of it.  Both you and farmerall!
Ben W.
  • diesel nut said thank you
#8 farmerall OFFLINE
farmerall
  • 2,207 Thanks
  • 1,475 posts
Posted November 01, 2013 - 09:16 PM
That's a nice tractor. It is possible that some one put a 12hp engine in there if the tag on the shroud say 12hp. I don't see why they would have pulled the engine to just swap a piece of sheet metal. The 10hp and 12hp blocks both are the same on the outside. I can think of a few ways to tell the engines apart but they aren't that easy because they both require some disassembly. The model number of the engine is cast into the block on the pto side of the engine but the pto clutch hides it. The other way would be to pull the head and measure the size of the bore. Personally if I owned the tractor and it ran good I wouldn't worry about what engine is in there until something went wrong with it.
  • jimbobbillyray and CubHorse80 have said thanks
#9 CubHorse80 OFFLINE
CubHorse80
  • 159 Thanks
  • 318 posts
Posted November 01, 2013 - 09:25 PM
So if i order a 12hp head gasket, it will fit a 10?
#10 IHCubGuy OFFLINE
IHCubGuy
  • 1,592 Thanks
  • 1,632 posts
Posted November 01, 2013 - 10:05 PM
Yes a K241 and a K301(10 and 12 HP) both use the same head gasket.  The tank that is on it is definately a 10hp tank.  The 12hp tank is more oval shaped than the 10hp tank and it holds more fuel.  Hard to say what has ever been replaced as it is all rusted and faded at the same rate, nothing sticks out as being a different shade of yellow.  It has been repainted as they painted over the headlight panel decal and grill mesh.
Whats the deal with the starter button?  Is it converted to a reguler style ignition switch or is the push button just missing?  Push button should be right next to the key switch in that hole.
Edited by IHCubGuy, November 01, 2013 - 10:09 PM.
  • CubHorse80 and Sawdust have said thanks
#11 CubHorse80 OFFLINE
CubHorse80
  • 159 Thanks
  • 318 posts
Posted November 02, 2013 - 12:05 PM
It has been repainted at one point, however it will be easy to get it smooth again. The rust is only surface. I guess it is a 10hp tank, but a 12hp engine?
He did psint over the front decal, but i was able to scrape the paint off whithout damaging it to much. It has been converted to a regular igniton switch, and i do want to change it back.
But where am i gonna get parts? CCspecialties is down cause of the fire...
  • IHCubGuy, Jlaws and Sawdust have said thanks
#12 IHCubGuy OFFLINE
IHCubGuy
  • 1,592 Thanks
  • 1,632 posts
Posted November 02, 2013 - 01:01 PM
Another good place for parts which I use for parts and decals is Madsons Service.  Good people with reasonable prices.  All the decals are available for that if you want to get all new ones.
#13 Jlaws OFFLINE
Jlaws
  • 556 Thanks
  • 368 posts
Posted November 02, 2013 - 02:23 PM
RallyRoperGT18 , nice find for the price , The fenders and the Ag's alone are worth more than that .
 I own a 100 myself and its one of my favorite cubs .
It looks like that 38" cast end deck has seen its better days , I have a couple if your looking for one .
I'm just across the river from ya .
I believe the 38 and 42 inch pin on cast end decks will fit .
I didn't know CCspecialties had a fire !!
I've bought parts from him in the past .
#14 diesel nut OFFLINE
diesel nut
  • 763 Thanks
  • 457 posts
Posted November 02, 2013 - 04:07 PM
I use IHCCW.com for parts when I can't find them local or dont have them at work.
#15 CubHorse80 OFFLINE
CubHorse80
  • 159 Thanks
  • 318 posts
Posted November 02, 2013 - 07:36 PM
I dont know if im goin to mow with it, but if you have a deck shell let me know! The ags are different sizes, but they are brand new! i need another bigger one to match the right side.
