Ditch Witch Backhoe - $1500 - Evansville, In
This topic has been archived. This means that you cannot reply to this topic.
3 replies to this topic
#1 BowlBuilder OFFLINE
  • 485 Thanks
  • 465 posts
Posted November 01, 2013 - 03:03 PM
Ditch witch backhoe with dozer blade in front the blade angles. Everything seems to work it runs and drives and the backhoe works for more info contact Dustin @812-305-5043
Please leave a message and I will get back to you
#2 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted November 01, 2013 - 06:57 PM
How do you steer it. I don't see any wheel? It's a pretty strong looking machine and a cheap BH if it does indeed work.
#3 jbumgarner OFFLINE
  • 72 Thanks
  • 109 posts
Posted November 01, 2013 - 07:11 PM
you steer by the levers.  I worked for DW for 5 years and that machine is surely older than I am, and it seems to be somewhat homemade if that matters.  The backhoe on the tractors should be on the front and a trencher mounts in the rear.  I think they took the BH and moved it to the back.  If it works it is a good price, but parts for the tractor may be hard to come by.  I'm pretty sure you can still get the BH parts.
#4 Cat385B ONLINE
  • 14,163 Thanks
  • 10,068 posts
Posted November 01, 2013 - 08:16 PM
Holy Carp, that's old. It has spark plugs!!!!!!!
