Ok You Seasoned Snow Pushers...do I Need Chains
35 replies to this topic
#1 york0060 OFFLINE
york0060
  • 310 Thanks
  • 146 posts
Posted November 01, 2013 - 09:44 AM
I have never used a garden tractor to push snow with before, i have the 318 outfitted with ag lug tires, 2 sets of wheel weights and a 75 lb lead weight hanging on the back. Do you think i will need chains or do you think i would get by ok with what i have?  We usually don't get the real deep snows here, most times about 4-8 inches at a time is a deep snow, except 2 years ago we did get 25 inches in one dump. Thanks for the input!
  • hamman, boyscout862, JRJ and 1 other said thanks
#2 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,436 Thanks
  • 2,860 posts
Posted November 01, 2013 - 09:54 AM
Haven't used a GT with ags before but if it were mine I would add chains. Not sure what you are plowing on, gravel, cement or blacktop. My BIL plows a large blacktop drive with an old MW. GT and he uses ags and chains and has no problem. JM2CW. Roger
  • york0060, JRJ and alley oop have said thanks
#3 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted November 01, 2013 - 10:00 AM
It kind of depends on where you are pushing snow. First time I took my 318 out with the blower on it went down the drive fine but I had to push it up the hill to the house. Put chains on before I ever went out again. They are worth the price in my opinion!!
I see your in SW Missouri. While I live in the Snowbelt and you do get some snow. I consider SW Missouri to be in the ice belt.
Temps normally are just enough higher than in Iowa  that you are more likely to get Ice and I consider Chains mandatory on ice.
Edited by JD DANNELS, November 01, 2013 - 10:01 AM.
  • york0060, hamman, JRJ and 2 others have said thanks
#4 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,294 Thanks
  • 9,777 posts
Posted November 01, 2013 - 10:02 AM
Yes!
  • hamman, JRJ and alley oop have said thanks
#5 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted November 01, 2013 - 10:12 AM
I had AG's on an X475 and it was pretty useless on my hill when it got icy. Even my 3000lb jd2320 with industrial tires needs chains. I say you should invest in a set. The size you need for a 318 aren't expensive and it makes a night and day difference when you need them. If you have any hills to deal with then it is a necessity IMO.
  • york0060, hamman, JRJ and 1 other said thanks
#6 boyscout862 ONLINE
  • 12,843 Thanks
  • 9,169 posts
Posted November 01, 2013 - 11:07 AM
You need chains but you don't have to spend alot. Used auto chains are often only $2 at garage sales. Front wheel drive radial tires should use cables so chains are obsolete for cars. These can be cut down to fit your tractor. There is a chain tool that makes it easy. Use some bungee cords as tighteners. Good Luck, Rick
Edited by boyscout862, November 01, 2013 - 11:08 AM.
  • york0060, hamman, sacsr and 1 other said thanks
#7 MH81 OFFLINE
Posted November 01, 2013 - 11:10 AM
Yes if you ever get any ice under or the buildup could turn icy.
  • york0060, hamman and alley oop have said thanks
#8 Talntedmrgreen OFFLINE
  • 3,273 Thanks
  • 2,306 posts
Posted November 01, 2013 - 11:55 AM
Another vote for YES, here. :thumbs:
  • york0060 and alley oop have said thanks
#9 HowardsMF155 OFFLINE
  • 2,861 Thanks
  • 2,987 posts
Posted November 01, 2013 - 01:20 PM
If your snowstorms tend to produce ice, then you must have chains.
#10 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted November 01, 2013 - 04:03 PM
A must on ice.
  • alley oop said thank you
#11 Petenpole OFFLINE
Petenpole
  • 154 Thanks
  • 157 posts
Posted November 01, 2013 - 04:29 PM
I am just up the road from you (KC)
I would trade the AGs for turf and yes you will want the chains.
Without chains you will slip slide down I-44 to Tulsa and Tulsa is a long ways to have to push uphill to Joplin.
#12 Arti OFFLINE
Arti
  • 1,363 Thanks
  • 989 posts
Posted November 01, 2013 - 04:30 PM
What will happen is that you will go along fine and then all of a sudden you start to spin, Then the snow under the wheel is now ice and you are now stuck.
Short answer Chains are necessary for winter on a tractor doesn't matter if it is a GT or a full size Tractor.
#13 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,319 Thanks
  • 4,953 posts
Posted November 01, 2013 - 06:53 PM
You will need chains!  :thumbs:
#14 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted November 01, 2013 - 07:36 PM
Have to agree...chains are a must!
#15 Bob IN OFFLINE
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted November 01, 2013 - 08:52 PM
My experience with chains is not a bunch, but if it was me I would get turf tires and chains. Chains fall down in-between the lugs and don't do much. That's just my opinion.  And honestly I think chains are a big pain in the back side. Just my opinion though.
