does anyone have a snow blower or now where I can get one for my 982?
Cub Cadet 982 Snowblower
#1
OFFLINE
Posted October 31, 2013 - 06:59 PM
- JRJ said thank you
#2
OFFLINE
Posted October 31, 2013 - 09:27 PM
Should be able to use the cub snow blower unless its different for those frames.
- JRJ and DuncanH have said thanks
#3
OFFLINE
Posted November 02, 2013 - 04:37 PM
DuncanH ,The 982's uses a different snowthrower than the other cubs and its a 450 model .
I think a 451 model made for the later cyclops supers can be made to work on a 982 with some modifications .
I have a QA-42A snowthrower made for the earlier wide frame GT's on my SGT 982 , it bolts up OK , but with the taller 982 front tires and axle it doesn't quiet lower all the way down . I also had to do a little modification ( which was a bolt on modification ) to the throwers lift arm .
I had to make it a little longer to clear the front axle .
The QA-42A has a 1/2 inch belt size pulley while the 982 front PTO pulley is made for a 5/8's belt , they do sell a cast 5/8's pulley to replace the 1/2 inch so that the QA42A can be used on the other 82 series GT cubs like the 583/682/782 etc.
With it mounted on my 982 and lowered its still about an inch above the ground but in my case that's OK since I have a gravel driveway and don't want it throwing gravel anyway , and I use a 54 inch power angle snow blade to cleanup what the thrower doesn't get .
Edited by Jlaws, November 02, 2013 - 04:55 PM.
