Synthetic Oil In 74 B&s?
4 replies to this topic
#1 BillTribbitt OFFLINE
BillTribbitt
  • 58 Thanks
  • 69 posts
Posted October 30, 2013 - 09:12 PM
            Is there any benefit to running synthetic oil in a 74' B&S? What weight is best to use?
  • JRJ said thank you
#2 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted October 30, 2013 - 09:16 PM
I use straight standard SAE30 in all my old engines.
Ben W.
#3 HDWildBill OFFLINE
  • 8,975 Thanks
Posted October 31, 2013 - 10:06 AM
synthetic oil tend to let the engine run cooler and lasts longer.  I run it in my bike with good results.  That being said I don't think I would run it in a 74 B&S engine. When synthetic oil first came out there was a problem with it eating seals and although you don't hear about the problem now a day's I wouldn't take the chance.  Plus the engine has probably had dino oil in it all of it's like and it is best to stick with the same type oil.
I usually put in what is called for by the manufacturer's manual, but if you don't have one then I would use the SAE 30 like Ben suggested. Can't go wrong with SAE 30.
#4 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted October 31, 2013 - 12:52 PM
I also would recomend SAE30 I use it in everything except the snow blowers and my Yazoo Red Rider due to a slight oil consumption issue that 15W30 helps to eliminate.
  • HDWildBill said thank you
#5 KennyP ONLINE
  • 38,223 Thanks
  • 45,861 posts
Posted October 31, 2013 - 01:56 PM
I've had 2 engines blow after switching to the synthetic. Won't use it again!
