Hydraulic Pump ?'s
johnson fel
10 replies to this topic
#1 TomLGT195 OFFLINE
TomLGT195
  • 3,829 Thanks
  • 2,814 posts
Posted October 29, 2013 - 06:48 PM
so the question is ; what pulley ratio do I use? would it be 1:1?  the motor is a Kohler K532 19.9 hp on my LGT 195 assuming full throttle 3600 rpm? ( is that correct rpm?) and the pump is the stock unit on a johnson model 12. I need to clean to see if there is any #'s on it . presently pump has 6" pulley so 6" on motor ? smaller or larger?
how many variables are there? any and all comments would be appreciated
Thanks Tom
#2 marlboro180 OFFLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted October 29, 2013 - 08:21 PM
Tom, I have not been on for a while, so I ptolly missed afew things in your query. What are you looking to drive via hydraulics?
Yes, 3600 RPM would be correct.
Best to get those numbers on your pump up here on the board so people can have a shot at making a resonable answer.
Either way, good luck :-)
Marlboro
#3 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted October 29, 2013 - 08:36 PM
You should be able to look up the numbers on the pump and find out all the specs. If you post them someone may have the specs to post.
Geno
#4 TomLGT195 OFFLINE
TomLGT195
  • 3,829 Thanks
  • 2,814 posts
Posted October 30, 2013 - 04:14 AM
marlboro, the pump is running a front loader
thanks Tom
 I will work at cleaning off the pump and see what i can find for markings
#5 Rock farmer OFFLINE
Rock farmer
  • 1,198 Thanks
  • 1,233 posts
Posted October 30, 2013 - 05:42 AM
The most important thing is clockwise or counter clockwise.
Joe
  • KennyP and TomLGT195 have said thanks
#6 skyrydr2 ONLINE
  • 3,886 Thanks
  • 3,410 posts
Posted October 30, 2013 - 06:32 AM
Start by running the pump 1-1 IF you need a little more speed you could run it up to maybe 4000rpm for the pump ,at max throttle (3600rpm engine)
  That pump looks to be about 6gpm , that should work nice for  your application.
  • Alc and TomLGT195 have said thanks
#7 TomLGT195 OFFLINE
TomLGT195
  • 3,829 Thanks
  • 2,814 posts
Posted October 30, 2013 - 03:34 PM
it came with the loader so it should be adequate . so 1:1 is where I'll start Thanks   and yes Joe that is the next thing ,orientation in tractor so it spins correctly with motor.  if anybody can point me to a supplier of pulleys that would be helpful, I will be bolting it in between the bracket off flywheel and shaft to hydro unit.
Thanks Tom
#8 TomLGT195 OFFLINE
TomLGT195
  • 3,829 Thanks
  • 2,814 posts
Posted October 30, 2013 - 07:45 PM
This looks like a good option for the pulley.a little pricey but looks like good quality
http://www.grainger....UDR0?Pid=search
Tom
Edited by TomLGT195, October 30, 2013 - 07:46 PM.
#9 Rock farmer OFFLINE
Rock farmer
  • 1,198 Thanks
  • 1,233 posts
Posted October 31, 2013 - 05:56 AM
This looks like a good option for the pulley.a little pricey but looks like good qualityhttp://www.grainger....UDR0?Pid=search
Tom
Tom,
I don't think that's the pulley You want. Your paying big bucks for the quick detachable hub! The hub will cost you extra. What's your shaft dia? Do you have a key way? What's your belt width?
The last pulley I bought was off Ebay, $10 plus shipping!
Joe
  • TomLGT195 said thank you
#10 TomLGT195 OFFLINE
TomLGT195
  • 3,829 Thanks
  • 2,814 posts
Posted November 01, 2013 - 08:23 PM
Joe,
Thing i like about that  pulley is the bolt pattern for mounting . I don't need a removable hub, just looking at that style hoping to find something similar but hopefully cheaper. Tom
  • Rock farmer said thank you
#11 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted November 01, 2013 - 08:54 PM
There is definitely an equally strong, cheaper and simpler way.
I buy the hub I want, with the bore size I need from Princess Auto, (sorry it's Canadian) and then a weldable sprocket or pulley to match. Its not changeable, but its solid and cheap.
it usually 15 bucks or so for the combo depending on size.
Maybe Harbour freight or some other place can do it for you. Possible McMaster carr, or ?
graingers prices are insane for the average joe. If you have a corporate account, then you can get better deals.
Edited by Chopperhed, November 01, 2013 - 08:54 PM.
Also tagged with one or more of these keywords: johnson fel
