A Year With The Ford 1500, 200 Hrs
9 replies to this topic
#1 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted October 29, 2013 - 09:48 AM
Actually a little over a year since I bought it the last week in September of last year.
And I am more than pleased! The only maintainence has been normal oil chances, a water pump, radiator cap and an ignition switch. Turned over 200 hrs, since I bought it (751 hrs) Sunday afternoon while plowing the gardens preping for a cover crop of Rye.
Over the past year, I have graded the 1/4 mile lane several times, alternating the rear blade and landscape rake. Plowed snow.  Plowed and tilled the gardens, mowed 8 acres several times. laid furrows to plant potatoes, plowed potatoes, moved mulch and many other items in the trailer.
In August I tore down the flood damaged home, by using the tractor to pull out studs till it collapsed. Then cleaned up.
And a multitude of other projects
A New machine would offer great improvement in Ergonomics and be more user friendly.
But I sure can't complain about the performance of this 1980 20 horse Tractor.
The only time I feel like I could use more power is when pulling the 5 ft brush cutter in heavy weeds and when using the 48" Gear drive tiller.
  • Alc, sacsr, Cat385B and 3 others have said thanks
#2 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted October 29, 2013 - 10:13 AM
Sounds like you are getting good use out of your 1500. Small utility tractors are very versatile and maneuverable and all you need in many instances. A larger machine would be faster at doing most things but costs more and takes up more space to store and to turn. Only 731 hours for a 1980 is low. Keep it well maintained and it will last a long time.
  • JRJ said thank you
#3 MH81 OFFLINE
Posted October 29, 2013 - 04:37 PM
After a year, you're still loving it. :thumbs:
#4 olcowhand ONLINE
  • 41,154 Thanks
  • 31,417 posts
Posted October 29, 2013 - 04:57 PM
Sounds like it's been a great investment that will serve you your lifetime should you choose to keep it that long.   :thumbs:
#5 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted October 29, 2013 - 07:07 PM
Over a year and you still start a thread without pics.............. :wallbanging: :wallbanging: :wallbanging:
#6 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted October 30, 2013 - 03:10 PM
Sorry Cat!! Been so busy the last few months there has not been time for any new pictures.
Funny part is I have had a new camera that long and have yet to learn how to use it.
#7 shorty ONLINE
shorty
  • 5,481 Thanks
  • 5,261 posts
Posted October 30, 2013 - 05:02 PM
Poor Cat, no pictures to look at. Or for me. But, :poke:  I think the Ford is picture worthy. :D  :D  :D
#8 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted October 30, 2013 - 07:59 PM
Don't worry, I haven't forgot that thread, either!
#9 BTS ONLINE
BTS
    Make Stuff Up
  • 4,259 Thanks
  • 2,457 posts
Posted October 30, 2013 - 09:48 PM
Sounds like it's doing good!
I have a '94 kubota L2000 (24hp), it to could be a little more user friendly but it's a great little tractor.
Take care of her and it'll last a long time!
Good luck
#10 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted October 31, 2013 - 07:59 AM
Good luck
Nothing wrong with the Kubota's either. The night I got home from buying the Ford, I got an email from a guy with a Kubota 3200, trying to set up a time to look at it. And the next day from a dealer with a 3200, that he had brought back to Des Moines so I could see it.
I had to tell them both it was too late.
