* * * * * 3 votes
Lgt 165 Repower **Updated with crawler conversion**
371 replies to this topic
#91 propane1 ONLINE
propane1
  • 9,156 Thanks
  • 4,285 posts
Posted March 28, 2015 - 04:54 PM
Was going to ask a question about the side plates for the chain, but I think I figured it out. The holes don't seem to be in the centre of the plate, top to bottom, but tell me any way just so I know for sure. And , I not having the building knowledge that you do, maybe it's just normal. Just wondering. Noel.
Edited by propane1, March 28, 2015 - 05:00 PM.
  • Chopperhed said thank you
#92 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted March 28, 2015 - 04:56 PM
I did that to allow the track to flex backwards when cockled by a rock, and to allow some sag on the top run. On reflection, I didn't need to put in so much offset. I probably could have used them with no offset, but I wanted to minimize wear on the pins.
Edited by Chopperhed, March 28, 2015 - 04:59 PM.
  • KennyP and propane1 have said thanks
#93 propane1 ONLINE
propane1
  • 9,156 Thanks
  • 4,285 posts
Posted March 28, 2015 - 05:10 PM
I thought it was for the sprocket to be deeper into the chain so there would be less chance of the sprocket to slip in the chain. Thanks for the info. Great build. I do some building , but not that detailed. Can't wait for end result. Noel.
#94 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted March 28, 2015 - 05:17 PM
Actually, that was part of it too. I figured with wear, the edges of the side plates would help the Tracks stay on the idlers and sprocket
  • propane1 said thank you
#95 TomLGT195 OFFLINE
TomLGT195
  • 4,018 Thanks
  • 2,884 posts
Posted March 29, 2015 - 06:15 AM
That blade looks reversible ? By design or coincidence? How thick, 1/4"?
Edited by TomLGT195, March 29, 2015 - 06:16 AM.
#96 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted March 29, 2015 - 07:03 AM
Coincidence, it's 3/16" plate.
  • Alc and TomLGT195 have said thanks
#97 Texas Deere and Horse OFFLINE
  • 14,863 Thanks
  • 15,511 posts
Posted March 29, 2015 - 09:48 AM
Good looking blade, can't wait to see it finished and pushing some dirt around !! :thumbs:
#98 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted March 29, 2015 - 10:04 AM
So for the last few days, I've been working on the front blade setup. I still don't have the custom bent piece I'm waiting for yet, so I built a quick setup using the beat up old Ford blade I have. From the way it looks I will have some serious articulation to play with.
I didn't expect so much tilt, but it was the shortest stroke cylinder I could get. 4"
I also doubt that I can do much at the extreme angles without doing damage unless it's really soft.
You can work with it, Google Patent Owensboro Ditcher & Grader Co., also Martin Ditcher & Grader and the modified Betty Trail Grader.
Stock drawn and in it's most basic form to start but could simulate ideas.
#99 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted April 19, 2015 - 02:53 PM
Got the blade finished up just before I broke the camera.
I thought I had pics of the new three spool control valve install, but apparently not.
Edited by Chopperhed, April 19, 2015 - 02:54 PM.
  • MH81, Alc, Texas Deere and Horse and 2 others have said thanks
#100 MH81 OFFLINE
Posted April 19, 2015 - 04:10 PM
Selfie?
:poke:
Sorry, it was the first thing that popped in my very tired brain.
The blade looks great, almost a shame to get it dirty.
What happened to the camera?
  • trowel and Chopperhed have said thanks
#101 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted April 19, 2015 - 04:24 PM
Selfie?
:poke:
Nope, dropped it, and it missed the rubber flooring by about 4 inches. Same thing happened to the last camera I killed. 8 years ago.
  • MH81 and propane1 have said thanks
#102 MH81 OFFLINE
Posted April 19, 2015 - 09:56 PM
I feel your pain, Ryan dropped a tablet this weekend at the hotel parking lot.
If the other stuff hadn't landed on it, it would've survived, I think.
  • wvbuzzmaster and Chopperhed have said thanks
#103 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted April 27, 2015 - 11:48 AM
Uploaded a new video covering the blade and ripper builds.
  • Texas Deere and Horse, KennyP, Cat385B and 3 others have said thanks
#104 camdigger OFFLINE
camdigger
  • 807 Thanks
  • 275 posts
Posted May 04, 2015 - 07:41 PM
If you have issues with your ripper shanks bending and you can tolerate the looks, think about using spike teeth off a chisel plow cultivator like the struck dozers.
Designed for the purpose, tough and relatively hard, available at any farm store in several different styles relatively inexpensive, especially if you know someone with a pile of half worn ones sitting out front of the shop.... Reminds me, I should move them before the weeds grow up through them....
  • KennyP and Chopperhed have said thanks
#105 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted May 04, 2015 - 08:01 PM
That's an option.
I've been looking for off the shelf stuff that I can fit.
I have a set of used cultivator teeth in the back corner. Working on a way to use them.
