* * * * * 3 votes
Lgt 165 Repower **Updated with crawler conversion**
371 replies to this topic
#226 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted June 21, 2015 - 09:04 PM
Can't wait to see a video. :thumbs:
  • Chopperhed said thank you
#227 MH81 OFFLINE
Posted June 22, 2015 - 06:53 AM
Phenomenal.
Its perfect and thank you so much for letting us watch your creation being born and its first steps.
#228 KennyP ONLINE
  • 40,036 Thanks
  • 46,727 posts
Posted June 22, 2015 - 07:06 AM
I like it!
#229 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted June 22, 2015 - 11:51 AM
A crappy vid of it rolling crawling off of the table.
I also discovered  I have a leak somewhere.
  • olcowhand, Alc, Texas Deere and Horse and 5 others have said thanks
#230 propane1 ONLINE
propane1
  • 9,114 Thanks
  • 4,274 posts
Posted June 22, 2015 - 01:44 PM
Nice video, not crappy, and my time was not wasted watching it. Would have liked to hear the engine and other sounds, music is nice, but engine sound is better. Thanks very much, can't wait to see it in action. Noel
#231 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted June 22, 2015 - 01:59 PM
I could leave the background noise in but someone might have an issue with copyright. I had Battlestar Galactica on the TV.
  • Alc, skyrydr2, TomLGT195 and 1 other said thanks
#232 olcowhand ONLINE
  • 42,298 Thanks
  • 31,771 posts
Posted June 22, 2015 - 02:31 PM
Some great work you've done, and came out quality looking as well !!  That tipping point off the table would have been the scary part for me.
  • Alc and Chopperhed have said thanks
#233 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,531 Thanks
  • 2,554 posts
Posted June 22, 2015 - 02:41 PM
Looks great!, when are you bringing it to KS so I can test it out??? :poke:
Can't wait to see it in action!
P.S, the video was great!
#234 Cvans ONLINE
  • 7,063 Thanks
  • 6,284 posts
Posted June 22, 2015 - 04:57 PM
Thanks for letting us look over your shoulder during your build. It's been fun and it turned out very nice.
Edited by Cvans, June 22, 2015 - 10:07 PM.
#235 KennyP ONLINE
  • 40,036 Thanks
  • 46,727 posts
Posted June 22, 2015 - 04:58 PM
I wish I were closer to see it in person. That is a very cool setup! Great job on the build!
#236 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted June 22, 2015 - 05:33 PM
The tipping (over center part) was a scary part for me as well. When I was  kid, loading the 3 was a scary occasion sometimes. Fortunately I had Uncles around to make sure I was blocked up and straight.
#237 TomLGT195 OFFLINE
TomLGT195
  • 4,010 Thanks
  • 2,881 posts
Posted June 22, 2015 - 07:49 PM
Nice job! Video was cool, can't wait to see it in action.
#238 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted June 23, 2015 - 02:35 PM
I've got the travel pedal adjusted and locked down.
Having a heck of a time making it turn left. The transaxle whines when turning both directions but doesn't seem to mind turning right so much, turning left it really complains. I know this transaxle has worn carrier bearings, I'm wondering if that's a big issue.
That and something thing appears to be leaking badly. Or it could be still run down from when I fired it up with the pressure line disconnected.
As an afterthought, it has to be the carrier bearings. It  changes from side to side as direction changes.
Edited by Chopperhed, June 23, 2015 - 02:55 PM.
  • KennyP, TomLGT195 and propane1 have said thanks
#239 KennyP ONLINE
  • 40,036 Thanks
  • 46,727 posts
Posted June 23, 2015 - 03:46 PM
You are putting a lot more load on things with the tracks. And that is a limited slip axle!
#240 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted June 23, 2015 - 04:21 PM
It's my bad to begin with. I noticed the slop in the diff half way through the build.
I have the brakes tightened up, and it's better, but.... I suspect that the worn planetary bearings are causing the whine, and the feeling that it's binding when turning. Sometimes it turns great in one direction, and then doesn't going backwards, but will turn fine the other way, and then vice versa. I suspect that the bad carrier bearings are letting the whole planetary gear float around, and depending on direction of travel, the changing loads cause binding.
As a side note, in straight line stuff it's been great. I had noo problem ripping 4" deep in a hard packed gravel alley,(don't tell the city).
I can raise the front end 6" and still push. I need a better cutting edge, it doesn't really bite like I want
Remember it was a hard packed recently graded alley.
I can't rip it up without reprisals.
