* * * * * 3 votes
Lgt 165 Repower **Updated with crawler conversion**
371 replies to this topic
#166 KennyP OFFLINE
  • 40,949 Thanks
  • 47,132 posts
Posted June 10, 2015 - 04:18 AM
Now i have to figure out why it starts great, idles smooth, and pops backfires, farts and bitches when I  idle up.
After having the carb  off today, I can't see a whole lot of room for tweaks.
My LGT 165 is doing the same thing. Haven't had time to mess with it lately.
  • Chopperhed said thank you
#167 TomLGT195 OFFLINE
TomLGT195
  • 4,054 Thanks
  • 2,901 posts
Posted June 10, 2015 - 03:40 PM
Is she still up on the table?
#168 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted June 10, 2015 - 04:05 PM
For a few more days.
I upholstered the seat this morning, I think I've got the steering squared away, and am working on getting the tracks back together. I still have to get the mixture thing figured out.
The ramps are too heavy for this double H guy, so I'm waiting for a buddy to give me a hand with those.
BTW, Also ordered the decals from Maple Hunter today. The exchange hurts but had to be done.
Edited by Chopperhed, June 10, 2015 - 05:48 PM.
  • TomLGT195 and propane1 have said thanks
#169 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted June 10, 2015 - 06:05 PM
Latest progress
  • MH81, Alc, KennyP and 3 others have said thanks
#170 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted June 11, 2015 - 03:34 PM
Well that was fun while it lasted. Two days messing with the carb and fuel lines, and I finally get it so it will run properly.
I got it all put back together, it was idling perfectly, I ran it up to 3000rpm and then this happened.
Can You say FRUSTRATED?
  • MH81 and propane1 have said thanks
#171 gardentractornut OFFLINE
gardentractornut
  • 325 Thanks
  • 322 posts
Posted June 11, 2015 - 03:57 PM
OUCH!! Is that what I think it is? The driveshaft and coupler?
#172 firstgen89sho OFFLINE
firstgen89sho
  • 82 Thanks
  • 90 posts
Posted June 11, 2015 - 04:21 PM
I have a spare coupler and driveshaft, just not sure when I will be in Edmonton again
#173 TomLGT195 OFFLINE
TomLGT195
  • 4,054 Thanks
  • 2,901 posts
Posted June 11, 2015 - 04:43 PM
I agree,  ouch!
#174 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted June 11, 2015 - 04:51 PM
I have parts for you if you want them. Is your dad making the trip anytime soon?
#175 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted June 11, 2015 - 04:58 PM
Yup. The coupler is fine, the driveshaft flange is bent, the rubbers are torn. I lost pieces of 5 fins off the plastic fan, which doesn't seem to bother anything.
What confuses me is how did this happen? The bolts didn't shear, they are all bent over
#176 gardentractornut OFFLINE
gardentractornut
  • 325 Thanks
  • 322 posts
Posted June 11, 2015 - 05:07 PM
You must have a bent driveshaft? or what else would cause that?
#177 KennyP OFFLINE
  • 40,949 Thanks
  • 47,132 posts
Posted June 11, 2015 - 05:24 PM
Low grade bolts maybe? Trying to figured out where it came loose! Pics are too close up! An 'I thought I had tightened them' moment?
#178 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted June 11, 2015 - 05:29 PM
They were torqued to spec, and had blue Loctite on them. I ran the numbers a while back, and even medium grade bolts should have no trouble with the torque.  I suspect, since I don't know for sure yet, that I'm missing a bushing in the coupler. The pilot on the driveshaft is 1/2", the hole in the coupler is 3/4" That's a lot of room to wobble. The other thing I question is the alignment of the shaft to the engine, since I had to make a motor mount plate to bolt the engine down, it raised the engine enough to cause interference between the driveshaft and the steering box. Since I removed the steering box, I didn't think it would matter.
  • KennyP, TomLGT195 and propane1 have said thanks
#179 propane1 OFFLINE
propane1
  • 9,470 Thanks
  • 4,398 posts
Posted June 11, 2015 - 07:53 PM
Was there any vibration at any time before it let go. It seems you had it running a few times before this happened. Ouch, that's not good at all. Noel.
#180 propane1 OFFLINE
propane1
  • 9,470 Thanks
  • 4,398 posts
Posted June 11, 2015 - 07:56 PM
Did it damage any thing on the engine? Were you trying to move it when this happened. ? Sorry for all the questions, just wondering. Noel.
