* * * * * 3 votes
Lgt 165 Repower **Updated with crawler conversion**
371 replies to this topic
#136 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted May 18, 2015 - 07:47 PM
Discovered a leak. No big deal just needs to be tightened up.
Was very slow. The blade would drop an inch or so per day
#137 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted May 19, 2015 - 07:31 PM
  And do you have any idea what is going to weigh when you are done. Bare tractor is about 800 lb or more. You have added a lot of metal to it since the start.
I figure it should weigh in around 1900 lbs, based on the original tractor weight, minus the cast iron engine, + the Honda clone + tracks, undercarriage, blade, and ripper + hydraulics
That is based on the steel weight charts, plus advertised weights of various components.
Edited by Chopperhed, May 19, 2015 - 07:32 PM.
  • Alc, gopher, TomLGT195 and 2 others have said thanks
#138 propane1 ONLINE
propane1
  • 9,114 Thanks
  • 4,274 posts
Posted May 19, 2015 - 08:15 PM
Thanks, figured it would be up there. Noel
  • Chopperhed said thank you
#139 propane1 ONLINE
propane1
  • 9,114 Thanks
  • 4,274 posts
Posted May 19, 2015 - 08:19 PM
With that weight , it should push very well. You will be more weight than most sub compact and some compact tractors. Can't wait to see it operate, and I am sure you can't wait to use it !!! Noel
#140 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted May 19, 2015 - 09:03 PM
I worry about being able to do it with 13hp. However, I have made allowances for, and am in search of, a bigger engine, possibly diesel.
I built the undercarriage to accept any Jacobsen built LGT, plus allowed for adaptation to a completely different driveline.
Still only about 2.15 lbs / square inch. less than 1/7th of atmospheric pressure at sea level.
based on 49" tread contact length, x 9" wide treads x 2 = 882 square inches. divided into1900 pounds
  • Texas Deere and Horse, TomLGT195, propane1 and 1 other said thanks
#141 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted May 28, 2015 - 02:18 PM
More progress.
I installed a shield to protect the hoses.
I wanted to be able to grease the rollers occasionally. With the difficulty of getting at each and every roller, I decided to grease the wear rail, since every roller will run on it.
I installed two grease guns under the right fender, with hoses connected to the rails. A few strokes on each lever every once in a while should keep the track well lubed.
  • Texas Deere and Horse, KennyP, skyrydr2 and 2 others have said thanks
#142 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted May 28, 2015 - 06:09 PM
SWEET!!!;; Now let's get the tracks on the ground!!
  • KennyP and Chopperhed have said thanks
#143 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted May 28, 2015 - 08:14 PM
Soon, So soon, I can almost taste it.
I painted the underside of the fenders today, with an application of Rust Check before hand.
#144 Cvans ONLINE
  • 7,064 Thanks
  • 6,285 posts
Posted May 28, 2015 - 10:47 PM
The grease gun idea sounds like a winner.  :thumbs:
#145 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted May 30, 2015 - 05:10 PM
I am so close, I can feel it.
I got the rear fender painted and mounted last night. I've been working on wiring, and figuring out how to mount the LED lights.
Now the next step is to find a source for decals that will ship up here. and finishing up a few niggly bits.
The Missus is in the US working on the spill in CA. I hope to be done before she gets home.
Edited by Chopperhed, May 30, 2015 - 05:15 PM.
  • MH81, KennyP, skyrydr2 and 2 others have said thanks
#146 KennyP ONLINE
  • 40,036 Thanks
  • 46,727 posts
Posted May 30, 2015 - 06:23 PM
Looks good!
#147 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,531 Thanks
  • 2,554 posts
Posted June 01, 2015 - 08:27 AM
WOW, I don't know how I missed this thread, it looks great!. I didn't have time to read all of it yet, but have test drove it yet?
Keep up the good work!.
#148 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted June 01, 2015 - 09:58 AM
No test drive yet, I only want to take it off the table once.
I did climb up and sit on it last night.
  • MH81 and Texas Deere and Horse have said thanks
#149 Texas Deere and Horse OFFLINE
  • 14,862 Thanks
  • 15,511 posts
Posted June 01, 2015 - 12:31 PM
Really looking great, can't wait to see how she does pushing some dirt.
How will you refill the grease guns, remove them?
#150 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted June 01, 2015 - 12:42 PM
The grease guns have a quick release clamp. I can pop the clamps and unscrew each gun to refill with a cartridge. I have just enough clearance under the fender.
  • Texas Deere and Horse, KennyP and TomLGT195 have said thanks
