May Need Some Help Rebuilding A K341
42 replies to this topic
#16 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 27, 2013 - 09:42 PM
That engine would scare the be-jezus outta me..
I'm wondering what I'm getting into. I think I'll pull the other engine apart and see why it's smoking. It may be better to use that one. My whole gt life is a mess lol
  • boyscout862, twostep and JRJ have said thanks
#17 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 11,243 Thanks
  • 6,065 posts
Posted October 28, 2013 - 05:18 AM
Just investigate what you have there and replace the rod with the correct one..  Check the cam spec's to what the Manual states for your engine in the Manual (you D/L & save it to your H/D yet?)  and if they are correct you will be fine!  Toss those 'Grenade Gears' into the scrap pile!!!
  • JRJ said thank you
#18 boyscout862 ONLINE
  • 13,546 Thanks
  • 9,427 posts
Posted October 28, 2013 - 08:29 AM
Who would put an engine together without cleaning anything?
Some people do some stupid things either through ignorance or... stupidity.
Ben W.
The difference between genius and stupidity is that only genius has limits. There is no limits to stupidity as our government likes to demonstrate.
  • bgkid2966, pigsitter, superaben and 2 others have said thanks
#19 boyscout862 ONLINE
  • 13,546 Thanks
  • 9,427 posts
Posted October 28, 2013 - 08:36 AM
I'd completely disassemble and clean that engine. Then I'd carefully inspect every part and wear surface with a magnefying glass and my mics. The cam would get the indicater treatment. Just follow the manual. Don't buy any parts until the inspection and any machining is complete. Good Luck, Rick
  • WNYTractorTinkerer and JRJ have said thanks
#20 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted October 28, 2013 - 04:32 PM
Is everyone saying the gear are not needed in the engine?? I don't know myself.  I would clean it up real good and reuse what you can. I think in the end you will be fine just getting in there and getting your feet wet.
That isn't even the work of a decent shade tree mechanic, but who knows what a PO would do to make a sale.  Good luck with the end product.
Like you had said you may need our help- well so far it looks you have a good following of helpful men.
Dick
Edited by JRJ, October 28, 2013 - 04:34 PM.
#21 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,103 Thanks
  • 10,175 posts
Posted October 28, 2013 - 05:53 PM
I recommend using the service manual that was listed. It's very good. I'm suspicious of the gasket shim. Was the deck previously milled, or was the man trying to lower the compression? I would take the engine apart and check everything. Mic everything.
#22 dodge trucker ONLINE
dodge trucker
  • 2,812 Thanks
  • 3,440 posts
Posted October 31, 2013 - 05:36 PM
It has two gaskets and a spacer. Supposedly the rod is to short per previous owner. All I know for sure is that there is no compression. Thanks for the manual. I downloaded it some time ago. I roughly thumbed through it tonight.
if it took 2 gaskets and a spacer the rod is either too LONG or the wrong piston is in there. Different engines may take the same diameter of piston but the wristpin hole location may be different  which will make it hit TDC at a different spot
That piston should stop directly even with top of the block before it starts back down as the crank rotates. There should be 1 head gasket between the block and head, that's IT.
#23 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted November 02, 2013 - 04:21 PM
This has the wrong piston and/or rod. The piston stops above the head but about even with the spacer. This engine is on hold until I get the other one apart. I'll post an update when I get working on it.
#24 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,103 Thanks
  • 10,175 posts
Posted November 02, 2013 - 05:25 PM
Can you imagine the work to machine that spacer? Woulda' been easier to change the rod.
#25 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted November 02, 2013 - 07:17 PM
I looked at it closer tonight. It actually looks decent but not professional grade.
The plate and piston numbers. By looking at the gaskets I would guess one old and one new.
Edited by BairleaFarm, November 02, 2013 - 08:58 PM.
#26 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted November 02, 2013 - 09:01 PM
#27 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted November 02, 2013 - 09:58 PM
Everything engine wise so far has been from engine M. Everything in this post is engine S. Engine S smokes to the tune of a quart a hour but I drove it in the shop when I tore it down for these pics. Pistons look the same rod from engine M appears longer.
The pics from engine S
  • MH81, bgkid2966 and boyscout862 have said thanks
#28 MH81 OFFLINE
  • 29,978 Thanks
Posted November 03, 2013 - 07:40 AM
Well, that kinda solves the mystery, doesn't it? What are the numbers of the two rods? ( if any)
#29 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,103 Thanks
  • 10,175 posts
Posted November 03, 2013 - 07:57 AM
Now that I see the picture, do you suppose he sawed the top off of another block?
#30 pigsitter OFFLINE
pigsitter
    enjoyin the livin part of life!
  • 1,229 Thanks
  • 1,083 posts
Posted November 03, 2013 - 08:02 AM
Definitely a difference in the rods,even the oil dipper on the end of the rod appears to be longer.
Just thinking out loud here maybe the longer rod and spacer were an ill advised attempt at building a long stroke k-series? Or am I giving whoever put it together to much credit in the IQ department?
