Can This Be Fixed?
20 replies to this topic
#1 BillTribbitt OFFLINE
BillTribbitt
  • 58 Thanks
  • 69 posts
Posted October 27, 2013 - 05:02 PM
  • JRJ said thank you
#2 BillTribbitt OFFLINE
BillTribbitt
  • 58 Thanks
  • 69 posts
Posted October 27, 2013 - 05:06 PM
#3 IamSherwood OFFLINE
  • 8,395 Thanks
Posted October 27, 2013 - 05:08 PM
Not seeing a picture there.
#4 BillTribbitt OFFLINE
BillTribbitt
  • 58 Thanks
  • 69 posts
Posted October 27, 2013 - 05:11 PM
hole in carb.jpg        Finally got it to load.     Can this be fixed or should I just get another carb?
#5 hamman ONLINE
hamman
    Homelite Owner Extraordinaire
  • 6,554 Thanks
  • 2,898 posts
Posted October 27, 2013 - 05:39 PM
Looks like the welch plug is gone, plus I don't see the upper part of the carb? Those plugs can be bought and reseated and staked in or put in staked and sealed with JB Weld. If the insides of the carb is good and you have the upper half of the carb it can be cleaned and rebuilt. I'm actually looking for a carb just like that. Good luck with it. Roger.
#6 boyscout862 ONLINE
  • 13,431 Thanks
  • 9,380 posts
Posted October 27, 2013 - 05:42 PM
That should be a large welch plug. Its hard to tell if that can be cleanned out and a new plug installed. Good Luck, Rick
#7 UncleWillie OFFLINE
  • 16,100 Thanks
  • 8,905 posts
Posted October 27, 2013 - 06:07 PM
I tell everyone that anything can be fixed, it all depends on how much money you want to put into it.
  • boyscout862, JRJ and AVB have said thanks
#8 olcowhand ONLINE
  • 42,313 Thanks
  • 31,777 posts
Posted October 27, 2013 - 06:44 PM
IF the seat for the welch plug is too damaged to hold a new plug, then you might be able to get an expandable rubber freeze plug that will fit the opening.
  • hamman, HDWildBill and JRJ have said thanks
#9 TAHOE ONLINE
TAHOE
  • 8,166 Thanks
  • 5,759 posts
Posted October 27, 2013 - 07:24 PM
That's what dad did for his carb like that.
#10 Rock farmer ONLINE
Rock farmer
  • 1,219 Thanks
  • 1,245 posts
Posted October 27, 2013 - 07:26 PM
Hell, you don't even need to break out the duct tape for that!
I used vynal electrical tape to fix mine!
Joe
  • hamman and JRJ have said thanks
#11 HDWildBill OFFLINE
  • 8,978 Thanks
Posted October 27, 2013 - 07:36 PM
Joe
How long did that hold?
  • boyscout862 and JRJ have said thanks
#12 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted October 27, 2013 - 08:03 PM
I'm more worried about the damage done when the carb was split.
The high-speed jet on the 45o angle and the tube behind it should be removed before the carb is split.
I did that once (the first time I rebuilt a Briggs carb), but was lucky.  I straightened the tube and it has worked perfectly since.
The carb kit should include the parts - the following is for the picture (I have no idea about the seller):
http://www.ebay.com/...=item2a33355c3f
This is a kit that includes the long brass tube and welch plug.
Btw., what would cause a welch plug to do that?  I'm guessing external combustion?
Edited by motobreeder, October 27, 2013 - 08:04 PM.
#13 Rock farmer ONLINE
Rock farmer
  • 1,219 Thanks
  • 1,245 posts
Posted October 27, 2013 - 08:04 PM
It's still holding. My thought was, the welch plug will blow out the first time the engine back fires. And, you'll lose the plug somewhere in the yard. Never to be seen again. So I just cut a piece of flat sheet metal and taped it on. If it back fires maybe it would still be hanging on. And I could just re-tape it.
As it happened, the carb fowled out and rather than re-build it again. I just bought a new one. When the plug blows out, you bypass the air filter system. And, draw raw and perhaps dirty air directly into the carb. I think most people are never even aware of this. I love my Simplicites. But, those B&S magnito ignitions and up draft carbs are the big downsides to me.
Joe
#14 HDWildBill OFFLINE
  • 8,978 Thanks
Posted October 27, 2013 - 08:14 PM
Looking at the picture, I just did thing the tape would hold that long around gas and oil.  Learn something new every day.  I'll have to keep that in mind for future use.  Thanks.
#15 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted October 27, 2013 - 08:29 PM
Yes, that plug is replaceable.  I would put in an original style plug versus taping, just because you can seal the intake so the mixture is correct.   You don't want that tape sucked into the carburetor body or (worst case) engine.  Just my thoughts there.
I have the welch plug and the carburetor kit (which includes everything you could ever need) as well as a few salvage carburetors, if anyone needs pieces.
Ben W.
