Bad Running 1450
6 replies to this topic
#1 2982 OFFLINE
2982
  • 1 Thanks
  • 3 posts
Posted October 27, 2013 - 03:45 PM
My buddy has a 1450 cub. He mows with it for 25 minutes and it starts spitting and sputtering. And it does this every time he uses it.we have rebuilt the carb.reset the governor. and replace fuel line and filter. What's next? thinking about valve lifter clearance.
#2 HDWildBill OFFLINE
  • 8,984 Thanks
Posted October 27, 2013 - 05:04 PM
You didn't say anything about checking the tank for garbage.  That would be the next thing I would check. When you rebuilt the carb did you pull the welch plugs?  W\hat about the plug?  Have you replaced it?  What does it look like?  It wouldn't hurt to check valve clearance's  although if all the above checks out I think I would start looking at the ignition circuit.
PS: when it starts sputtering have you tried to open the gas cap to see if smoothed out.  Could be a plugged vent.
  • bgkid2966, boyscout862 and 2982 have said thanks
#3 IHCubGuy OFFLINE
IHCubGuy
  • 1,611 Thanks
  • 1,638 posts
Posted October 27, 2013 - 07:11 PM
Does it shut off when it does this?  If so it could be the coil is closing.
  • 2982 said thank you
#4 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted October 27, 2013 - 07:24 PM
Hello and welcome! :wave:
#5 KC9KAS ONLINE
KC9KAS
  • 5,464 Thanks
  • 4,722 posts
Posted October 27, 2013 - 07:26 PM
:welcometogttalk:
#6 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted October 27, 2013 - 08:36 PM
Welcome to the forum!
Are you getting fuel flow as it shuts off?  Maybe we have vapor lock going on.
Ben W.
#7 2982 OFFLINE
2982
  • 1 Thanks
  • 3 posts
Posted October 28, 2013 - 04:11 PM
The tank is clean and lve done everything you all have mentioned except the egnitation switch. Thank to all of you for the welcome and help. I will let you know what happens.
