Picked This Nice Original D4-10
23 replies to this topic
#1 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,446 Thanks
  • 3,360 posts
Posted October 26, 2013 - 06:05 PM
I picked this up this week with some parts. Has a 1967 TRA-10D motor. Was not getting spark, but I had a nos condenser and points on hand. Replaced them and it fires right up. But it wants to run wide open. It was missing some springs for the governor, but I had extras and a complete TRA-10D to use to compare. The piece is missing that the idle screw bumps on, but that should not make it run wide open. I can turn the throttle by hand and keep it running in a decent range. Soon as I let go, it goes back to running wide open. Any ideas?
  • Alc, Texas Deere and Horse, hamman and 3 others have said thanks
#2 KennyP ONLINE
  • 37,394 Thanks
  • 45,448 posts
Posted October 26, 2013 - 06:32 PM
It's ready to go to work! "Don't keep me sitting here, work me"!
  • sacsr said thank you
#3 DH1 ONLINE
DH1
    Electric Tractors
  • 5,231 Thanks
  • 5,546 posts
Posted October 26, 2013 - 06:35 PM
Where do you find these?
I haven't seen 1 come up for sale north of the border for a long time.
#4 IamSherwood OFFLINE
  • 8,390 Thanks
Posted October 26, 2013 - 06:36 PM
Good looking machine. At a glance, it looks like it has BIG front tires
in the 3rd picture. Kind of a cool look.
Sorry, can't help with that rev problem.
#5 olcowhand ONLINE
  • 40,329 Thanks
  • 31,166 posts
Posted October 26, 2013 - 06:39 PM
If there is no pull on the governor arm from the throttle cable, and the governor rod is connected to the carb, then either someone has messed with the governor adjustment, or the governor is shot inside the engine.
  Great looking D4-10!!!!!!!!!!!
  • sacsr and boyscout862 have said thanks
#6 ckjakline OFFLINE
ckjakline
  • 1,139 Thanks
  • 1,129 posts
Posted October 26, 2013 - 07:19 PM
Nice looking original tractor.Nice find.
#7 Burl OFFLINE
Burl
  • 111 Thanks
  • 43 posts
Posted October 26, 2013 - 07:55 PM
Scott, that is a very complete find!! I noticed the decal for the spin type park brake. Now we know! Sweet!
#8 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,446 Thanks
  • 3,360 posts
Posted October 26, 2013 - 08:00 PM
Doug I was lucky enough to find this one with in 3 hours of my house. They seem to come out of the woods, especially since a lot of people see I am collecting them.
Kinda like how all the Electra Tracs seem to find you! Wish I had you skills, I need to tinker with my E-15 this winter and get it going!
  • DH1 said thank you
#9 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted October 26, 2013 - 08:28 PM
Not having worked on a TRA Wisconsin, I don't know much.  But I do see the parts diagrams where it shows that the governor arm is clamped to the shaft by a screw.  If that was worked loose, it would throw the governor off.  I've seen it happen on a Kohler before.
Ben W.
  • MH81, Texas Deere and Horse, EricFromPa and 2 others have said thanks
#10 EricFromPa OFFLINE
EricFromPa
  • 3,512 Thanks
  • 3,064 posts
Posted October 26, 2013 - 10:12 PM
Ben W.
Yep that happens to Wisconsin engines to.
Set your throttle lever to the Idle position and loosen the cable tie so that you can set the throttle cable.I've had more than a few that just needed the throttle cable set so there is no tension on the governer.That should alow it to idle down.
Here's how to reset the governer.
Edited by EricFromPa, October 26, 2013 - 10:13 PM.
  • olcowhand, sacsr and superaben have said thanks
#11 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted October 26, 2013 - 10:50 PM
Really nice BH Scott, way to go buddy. You have all the luck finding !!
#12 olcowhand ONLINE
  • 40,329 Thanks
  • 31,166 posts
Posted October 27, 2013 - 08:01 AM
I don't think it's luck that he finds them....he works like a dog on a hunt to dig them up!  Good work Scott!  How many of those Hogs can you pile on a trailer to take to a Bush Hog reunion?  :D
  • Texas Deere and Horse and sacsr have said thanks
#13 MH81 OFFLINE
Posted October 27, 2013 - 08:13 AM
  • olcowhand, Texas Deere and Horse and sacsr have said thanks
#14 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,446 Thanks
  • 3,360 posts
Posted October 27, 2013 - 06:19 PM
Well I reset the governor and loosened the throttle cable- cranks ever time, but still wants to go to wide open:-(
So any chance it's the carburetor? Or do I have to pull the motor and the rear plate off the motor and check the governor?
Really not looking forward to that.
#15 olcowhand ONLINE
  • 40,329 Thanks
  • 31,166 posts
Posted October 27, 2013 - 06:33 PM
If you set the governor correct, and there is nothing from a throttle cable pulling on it, then sorry, it's governor rebuild time.  :(
